Question about ACE Allway Tools Allway Handy Saw Blades
Need replacement blades for old Allway Super saw
Band saw blade twists while trying to cut a straight line
The replacement blade could be defective.
Jul 30, 2016 | Blade Saws
Remove blade on circular saw ks865. motor turns when nut is turned thus unable to undo. Blade cannot turn because it has a screwdriver in the hole provided. Presumable the nut and washer is a bit loos
Take the saw to a bike repair shop. They have super thin wrenches to fit behind the blade and the motor that will hold the armature still while you loosen the nut on the front.
Oct 09, 2014 | Saws
How do I change the blade on model #17224 saber saw?
Are you talking about a reciprocating saw? What brand? If this is what you're referring to, then there is usually an Allen style set screw at the base of the blade. Loosen the set screw with an Allen wrench, and replace the blade. Retighten the set screw and cut away.
Oct 06, 2014 | Saws
Jammed my 6230 bandsaw during a cut and now it won't start. Are their fuses I can replace?
Go to Milwaukee Tool website and try to check if you can download a manual or electrical diagram there. You can call or email them. Check the motor capacitor.
Are you using an old or new band saw blade? If it's old/dull, try different blade. If it's new, the weld might be really bad. Old Blade and Bad weld can cause the blade to jump off. I purchased band saw blades on www.sawblade.com . Great quality blades; they have porta band blades. Call them.
Oct 23, 2013 | Milwaukee Tool Milwaukee 6230 Deep Cut...
I inherited a very old Fury F-7 circular saw from my Dad. It uses a 7-1/4 diameter saw blade. This is sorta-kinda embarrassing, but for the life of me I cannot figure out how to lock the shaft to replace...
Most times when I need to change a blade on my 7 1/4" saw I simply grab the blade on the front side, below the saw's support table, with a pair of channel lock pliers and then use the box end wrench on the blade nut, pushing down from the back side of the saw blade. That should loosen the nut so you can take it out with your fingers. The reverse of this procedure should tighten the nut on a new blade.
I'm not real familiar with the Fury saw, but if it requires saw blades with the diamond shaped cut-out in the center, most of the older blades had a knockout that will fit the diamond shape it would need.
Apr 22, 2011 | Now Evolution #Fury 7 1/4" Mp Circular Saw
How to tighten blade on super sawcat model 2154 , blade spins and I cant find any way to stop spindle from spinning when Im trying to tighten . Any help would be great as was my fathers saw and would still...
Usually on portable saws there is a hole somewhere in the blade guard to put a screwdriver or something through and hold the blade still while you tighten the spindle nut etc.
Hope this helps. I only have experience of a very old B&D saw which worked in this way. I now use a more modern Bosch machine which also works the same.
Jun 04, 2010 | Saws
Blade comes off wheel on horizontal saw have a wilton 7040 horizontal saw. after cutting about 1/2 thrru a piece of metal the blade sticks and then stars comming off the right wheel and starts cutting into...
if its a new blade, make sure that it is the proper length for the saw, sometimes aftermarket blades look like they are the right size but the difference of a few mm can cause the blade to track. if its an old blade, it could just be dull enough that it is binding on the material you are cutting and this draws the blade off the wheels. even if the blade isnt that old or seems sharp, if you have a brand new blade handy that would be the easiest thing to try.
your manual will have instructions on how to adjust the blade guide bearings. if this is a new saw, it SHOULD be set properly and be working from the factory but they may still need to be adjusted. an older saw obviously may have shifted a bit from normal usage. if you dont have a manual one can be downloaded from the wilton tools website.
before adjusting the guides, though, check to see that the bearings spin freely. if they do not spin smoothly with minimum pressure, they need to be replaced. they also should be replaced if they spin VERY freely because this is also an indication that they are pretty worn and may actually be binding up under pressure.
Dec 02, 2009 | Wilton Saws
Can not remove the old blade
1. Unplug the saw.
2. Locate the blade lock button used to lock the motor shaft when changing a blade. For your saw, this button is usually located on the left side of the blade guard somewhere around the motor housing.
3. Push the button while rotating the blade until the button engages and the blade will no longer turn.
4. Use the wrench that came with the saw (or another wrench) to loosen and remove the blade bolt. For your saw the bolt should have standard right hand threads which means you loosen the bolt by turning it counter clock-wise.
5. Remove the old blade and replace it with a new blade of the same mounting type. Some blades have a round through hole and some blades have a diamond through hole.
6. Re-install the blade bolt and tighten clock-wise while holding the blade lock button down.
Oct 03, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
REPLACE BLADE IN MOD #172.171800 8.0 A, CRAFTSMAN, RECIIP SAW
If you see a set screw where the blade goes, loosen it a few turns. Then run the saw, it should spit out the broken blade. If it has a manual release for the blade, press the release while tapping the blade holder.
Apr 29, 2009 | Craftsman 8.0 amp Reciprocating Saw
Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Aug 31, 2008 | Saws
ACE Allway Tools Allway Handy Saw Blades Logo
Top ACE Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an ACE Measuring Tool and Sensor Expert? Answer questions, earn points and help others
