Question about Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING
Cash drawer won't open on my 5200
Trying to input discount key for happy hour price now the drawer does not open the alarm bell sounds but nothing happens.
When turning on our sharp XE-A42S cash register in REG mode it lets us enter in a price, but when we go to push the department key, it beeps and displays misoperation...
Firstly, press subtotal (ST) button. If a price appears, you are in a sale and it is waiting for you to finish (try another method like credit). If it gives an error or beep when you press ST button and the drawer does not open when pressing CA/AT/NS, you probably haven't signed on. Try signing on using a PIN number (see clerk sign on in your manual)
Jan 11, 2017 | Sharp XE-A42S Cash Register
How to program bottle deposit on xe-a507
PartsandTheirFunctions Printer cover Operator display Keyboard Drawer Check slot Drawer lock SD card slot (Refer to the "SD CARD Mode" section.) Printer The printer is a thermal printer, and therefore it does not require any type of ink ribbon or cartridge. The average life of the printer is approximately 6 million lines. When removing the printer cover, lift up its rear. When installing the printer cover, hook it on the pawls on the cabinet and shut it. CAUTION:Thepapercutterismountedontheprintercover.Becarefulnottocutyourself. Keyboard ? Keyboardlayout ? Functionkeylist { Receipt paper feed key PLU/sub-department/UPC key } Journal paper feed key Department code entry key Function menu key Department shift key a Auto key CLK# Clerk code entry key w Tax1 shift key Department 1-40 key 0 Percent 1 key FI Cursor (up/down arrow) key - Discount key m Mode key t Void key Escape/Cancel key H Help key X Charge 1 key f Refund key R Receipt print key @ Multiplication key Y Charge 2 key P Decimal point key u PLU/UPC inquiry key l Clear key x Check key 0 9 : Numeric key ; Non-add code/Time display/Subtotal key A Cash/Amount tender/No sale key Displays ? Operatordisplay •Screenexample1(REGmode) Salesinformationarea: When a transaction information occupies more than 2 lines, you can scroll to the direction by using the F I keys. Sales information you have just entered such as items and prices will appear between 1st line and 2nd line. Total is always appear at 3rd line. NumericEntryArea: Statusarea: Mode name Status information Clerk code Receipt ON/OFF status indicator (R) : Appears when the receipt ON-OFF function signs OFF. Sentinel mark (X) : Appears when the cash in drawer exceeds a programmed sentinel amount. The sentinel check is performed for the total cash in drawer.
Sep 28, 2016 | Sharp ELECTRONICS CORP. Xe a203 cash...
When pressing the department key, the cash drawer opens after each transaction, is there a way to stop this?
You have programmed SICS or single item cash sale. Check the programming for that department and set SICS to off
Jul 21, 2015 | Samsung Retail Supplies
My Samsung ER-4915 won't open drawer when cashed out
It sounds like someone has reprogrammed the status of the cash button. Can you finish the sale with a different payment type such as credit card button?
Jun 26, 2013 | Samsung Computers & Internet
SHARP ER-A410 CASH REGISTER DRAWER WON'T OPEN
Does it open when you print a Z report? The most common problem with these was either the drawer wiring or drawer solenoid failing.
If anyone needs more information, the Sharp ER-A410 and ER-A420 manual is here:http://the-checkout-tech.com/manuals/cashregisters/Sharp6.php
Oct 20, 2011 | Casio Parts Cash Register PC Desktop
I have tk1300 casio cash register. i have input my new tax rate and now it ring up right tax with product, but only work when i used credit card button(CH) and it print and open the cash drawer. It beeps...
It sounds like you have programmed the CASH button. Try this:
Turn key to program mode 0 CASH SUBTOTAL 3 SUBTOTAL 0 CASH SUBTOTAL Turn key back to REG and try it.
If anyone is looking for a Casio TK-1300 manual, http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-1300_and_CE-4200_and_CE-4250_programming_manual.html
Jan 27, 2011 | Casio Parts Cash Register PC Desktop
Alarm on continuously!
please try to reinstall the printer drivers
Feb 13, 2009 | Citizen IDP3541 Matrix Printer
Help
HI Jodi
I have worked with these machine many years ago but from what I can remember. I think you turn the key to P hold down the C button turn it on and it should clear the memory . It sound like it is in a loop.
Good Luck
Oct 25, 2008 | Casio Parts Cash Register PC Desktop
Error code
First check to be sure there is not a key stuck down. Not sure what type of cash register you have. Many times you have to perform a RAM clear and reprogram. Sounds like you have lost the program. Also is the drawer closed some registers have a switch and also need programming to operate the keyswitch with the drawer open...Good luck
Jun 27, 2008 | Office Equipment & Supplies
Samsung Sam4s ER-5200M Cash Register WITH PROGRAMMING 1-800 SUPPORT FRRE SHIPPING Logo
62 people viewed this question
Top Samsung Retail Supplies Experts
Patrick Tinashe...
james laughton
james laughton
ray gallant
Are you a Samsung Retail Supply Expert? Answer questions, earn points and help others
