Question about Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless
Broken drill charger
Charger stopped working
The drill is on the base but the battery lights are not coming on and it won't charge. It has been on the charger all night and hasn't charged at all. It worked fine up until now. I've only had it for...
You should check first using multitester, the voltage that comes out of the drill charger. if the stress is normal in accordance Battery voltage required by the drill, the damage there is on these batteries, the batteries serve targeted cell is damaged or broken connections between cells in these battrey. so the charger can not charge battery, indicator lights would not light up.
Jul 27, 2010 | Drills
Need battery charger for robust 18v drill/driver. charger model 9706
need battery charger for robust 18v drill/driver. charger model 9706
I have exactly the same charger with the battery .
my drill is fallen , and it is broken .
Jul 13, 2010 | Drills
The charger simply stopped working. I don't want to buy a whole new drill. Where do I get another battery and charger? s.g.
Check with Ace Hardware, they will direct you to the manufactere for a replacement charger or perhaps a place that sells aftermarket chargers...sometimes you pay more for a charger then you would for the whole drill assembly, especially if they run it on sale.
Jul 02, 2010 | Ace Hardware PowerGlide 18V Trigger...
Makita 1850 battery charger FIX. A friend asked me to check his charger unit which had failed after it had been connected to a portable petrol generator that incorrectly generated 317 Volts AC and not the...
I have a BL1830 Lithium Ion LXT battery that will not charge because the charger tells me the battery is broken. I have taken the battery apart to find no problems with the connection from cell to cell. There is a small circuit board that I cant find any visible signs of damage on. The battery will still run a flashlight or a drill but it is almost drained.
May 16, 2010 | Makita Drills
Bought 2 no BTD142 impact drivers from Makita USA got drop down transformer they just start to charge then tones for broken battery are heard and stop charging, transformer new, batteries new have i done...
these newer chargers do make a tone that can be changed. when the batterys are initially inserted they will make a sound and then when they are fully charged they will make another usually longer sound. you can change it by removing the battery with 5 seconds and reinserting until you find the sound that you like.. I would look at the charging lights before deciding the charger or battery are bad.
Nov 22, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
I have a Craftsman 19.2 charger that stopped working...
OK, I had trouble with craftsman 19.2 charger stopped working. I took them a part and found there is a lever looking plastic piece that turns the switch inside the charger. The lever gets pushed by a battery and it pushes the switch. Well, over the years of use, the tip of the lever got rounded on mine and not be able to push the inside switch in all the way. So I just super glued a little plastic on the lever piece and put the battery together. It's been working fine ever since.
Sep 17, 2009 | Craftsman Drills
Kawasaki drill charger
no warranty ?
well,as for me,i would rather find any DC charger that suits the voltage output for the battery..
smaller ampere gave longer recharging time but keep your battery cool during charging...
Mar 30, 2009 | kawasaki Drills
I have two 18 volt cordless drills . both chargers have quit working , and they are not even two years old . how can i get help?
the charger rearly fail. it must be the battery problem.have your battery tested also the switch of the drill.if the drill runs slower than use to be changed the switch.
Jul 05, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt Hammer Drill Sds2x18 V Batt 5 Sds Bits Cordless Logo
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
