Question about Epson Stylus Office Equipment & Supplies
All the lights on my printer are flashing and it won't print or copy. I've had this printer for more than a year and a half and I just started using it after some good 8 months. I just replaced the in
Even the 4"x6" photo paper is on. The ink box won't move either.
    Sergeant:
  • 242 Answers
Maybe a mechanical jam, otherwise it's the electronics.
Posted on Nov 17, 2013
4 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: HP Photosmart C4180 won't load photo paper
Remove the rear access cover and clean the black rubber rollers with alcohol.
Posted on Feb 16, 2009
SOURCE: epson stylus photo 950 printer flashing lights
I had the same Problem and checked the solution:
This is a Printer Maintenance request.
Ink Overflow -
you sould change the waste ink pads under the printer mechanic.
Solution:
cabrooksjr
  • 13 Answers
SOURCE: Paper feeds crooked into the printer
Check the adjustments for the paper your using. Open the printer and look on the rollers you'll probably find paper or an obstruction clear it and also clean then rubber moving parts with isopropyl alcohol to give them their grip back.
Posted on Jun 21, 2009
Why does my MX420 stop printing halfway?
Hi . If copies are doing fine maybe is a network or drivers issue
May 17, 2017 | Canon Pixma MX420 All-In-One Printer
I can't make a copy using the operator's mode. the copy that does print is so light and such small print thatit can hnardlyh be read. Also, the copy that comes oujt is only half of a page. Most of the
It sounds like the settings on your printer in the menu area have been set to reduce the image you want to print? Click on menu and then scroll the features with the up and down arrows and check on the size of the image to print and change it if necessary.
Please clairfy what you mean by "using the operators mode".
Oct 21, 2011 | Dell V305 All-In-One InkJet Printer
I've changed the ink cartidges but the black and color ink lights remain on and it won't print. I think the E2 error message is on.
This hapens when refilled cartridges are installed in the printer. To rectify the problem, look for the 'Resume button' normally black with a red circle around an arrow head pointing towards you. With the printer powered on, press and hold this button down for about 10 seconds. The error code will usually clear and the printer will print but the orange lights will still flash.
Sep 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Hp 2115 - clicking noise from carriage, can`t print test page
I have an HP 6110 is always has a grinding noise.No functions work. HP just want me to buy a new machine. They are bad quality 3 in one's. That is for sure.
Jun 28, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Cannot print my documents
well you can probaly send it to your email then use your buddys computer because i ve never heard of that problem before thats all i know
Jun 07, 2009 | HP Deskjet F340 All-In-One Printer
C3150 print cartridge
  • Remove the cartridges.
  • Turn off the printer.
  • If the cartridges are leaking, put the print head on some tissue, so it can extract the excess ink. With a dry cloth, clean your scanner. Look inside the printer. If there is ink in there too, clean it. Use a lot of tissue or toilet paper. Might put some gloves on too.
  • When you make sure that the cartridges are not leaking anymore, gently wipe the electric contacts on them, and clean the ones on the cartridge carrier.
  • Turn the printer on.
  • Try printing.
  • If the cartridge light keeps flashing:
  1. If a computer message indicates a specific cartridge, that is the problem cartridge.
  2. If there is no computer message, look at the Start Copy lights - if the Black Start Copy light is blinking, the cartridge on the right is the problem cartridge.
  3. If the Color Start Copy light is blinking, the cartridge on the left is the problem cartridge.
If you find out which cartridge is the problem, you will need to replace it.
Unfortunately, the ink that has leaked inside, might have damaged your printer.
Dec 31, 2008 | HP Photosmart C3150 Printer
Won't print after warms up
Check the status of your fuser unit. If it is ok then the problem comming from main board.
Nov 16, 2008 | Brother HL 5250DN Laser Printer
Brother MFC-440CN won't print color
Did you use generic carts?
Do use only original brother ink carts!
Only these have special cleaning fluids mingled with the ink.
There are several advantages, too:
You can run a special cleaning mode (DO insert original carts at first!!!)
Press menue then start bk copy then fourtimes arrow-up.
machine should switch to maintenance mode (buttons will flash).
press 7 then 6 then 4 then start bk copy. machine will refresh ink within the tubes and the print head and run a special cleaning routine. when finished press 7 then 6 then 3 then start bk copy to run a power cleaning. leave the maintenance mode by pressing 9 then 9.
The machine should print without proböems. If there is a poor quality left, the printhead is affected by bad ink and cant be fixed anymore.
Jan 24, 2008 | Brother MultiFunction Center MFC-440CN...
26 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
