Question about U-Line CO2075F-B Echelon Refrigerator Ice Maker Combination
The bucket that holds the ice is freezing all the ice together and then it will not come out of the dispenser
  • U-Line Master
  • 842 Answers
You have a bad water valve, this causes water not to stop entering the unit and causes one big cube. You didn't mention any ice or frost behind the ice bin so I will assume you have none. the water valve should correct this issue.
Good Luck
Posted on Nov 17, 2013
How do I Prevent ice dispenser from freezing up? Ice is in the ice bucket but will not disperse.
The ice stays in the cubemaker tray for a set time and then empties into the bucket. If the freezer was too warm the ice wasn't frozen enough when the cube maker emptied it and it all stuck together. Now the fridge is cold again empty the bucket, make sure there is no ice stuck in the dispenser and try again. If it is a Samsung fridge do the above and turn it off for 30 seconds and back on again. Sometimes the controller and display freezes and reads the wrong temperature.
Nov 18, 2014 | Refrigerators
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
My ice in the ice maker seems to be melting together and they are fusing into big ice cubes that cannot dispense/
This tends to happen when ice has sat in the ice bucket for a couple days of non use. The warmer your kitchen the worst this tends to happen. What's usually happening is the ice bucket is sitting on the door where the ice dispenser sends it to your glass. Since the cavity in the door is exposed to the warm air in your kitchen it can work its way to the ice bucket area via the chute in the door and when the moist warm kitchen air reaches the ice cubes in the bucket it turns everything into melting ice cubes which eventually freezes at some point and clogs up the ice bucket with large globs of ice pieces that the ice crusher can't handle. About the only thing to do is remove the ice globs from the bucket and make new ice. This is not all that abnormal, just a pain though. Try putting something in the chute (small Rag?) to see if this stops it. If it does then there's not a whole lot you can do about it but use the ice machine more often so it doesn't all sit there melting together.
Sep 25, 2014 | Samsung RFG237AARS Bottom Freezer French...
Will not dispense ice
commonly what you will find on that model is the main control board on the back of the unit is the source of your issue, it begins like a computer virus where the unit will render the water in the door feature useless, next goes the ice delivery sys, then the unit does not defrost properly causing cooling issues. But before running out and getting a new control board go by this check list first: 1) make sure your ice bucket is properly seeded, 2) make sure the ice in the bottom of the bucket is not melted together if so empty good ice in seperate container and put back in freezer quickly to avoid melting then run hot water in ice bucket to melt remaining bad ice afterwards completely dry ice bucket and put good ice back in and see if it works properly, 3) make sure the auger mtr is not seized due to door being left open and humidity freezing in mtr gear.
Apr 16, 2012 | GE Refrigerators
Door Ice Dispenser not dispensing Ice
Jeff; I would start by taking the ice bucket out and totally defrosting it! Sometimes water will freeze holding the auger in place and a simple defrost will cure that problem.
Hope this helps!
Hal aka ImJustAvg
Jan 08, 2012 | Whirlpool Refrigerators
Ice in bucket freezes into a lump, mechanism freezes
it sounds like the ice chute door is stuck open. on this model it can slip off the "hinge pin" or the plastic that holds the pin can break. if the flap is broken it is replacable. the pin can be put back in. if the plastic that holds the pin is broken, you need to replace the whole door. expect to wait 6-8 weeks for a new door, sooner if lucky. cost is $400 +++ more for stainless.I hope the pin fell out. hope this helps
Jun 16, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Side by side refrigerator - LSC 27950SW - looking
most likely water is running out the corner of your ice maker and into auger bucket and freezing not allowing it to dispense.check bucket to see if sheet of ice is forming.
Mar 06, 2009 | LG LSC27950 Side by Side Refrigerator
Ice maker problems
If the ice bucket is over filling there may be a problem with the ice maker as this should stop making ice when the bucket is full. The ice in the bucket can freeze together just due to the weight of ice cubes . I suggest you check the ice within the bucket is all broken up and not frozen into big lumps
Aug 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice Dispenser Doesn't work...
sounds like the water coming into the icemaker is spilling over or leaking into the ice despenser bucket.... check for ice build up or plugging of water chut into ice maker
Aug 08, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
61 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
