Question about Pioneer Audio Players & Recorders
Window shows NO DISK when there is a disk in the unti
Worked one day and not the next...can hear the gears moving, but it shows NO DISK in the window
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 924 Answers
If the CD manually loads correctly, the pickup(laser has gone bad) and no longer has enough power left to read the disc the TOC, (table of contents), showing no disc on the display. If you're interested in a repair, please contact me through my website, audioserviceclinic.com. Thank you.
Posted on Jul 05, 2014
Window gets stuck on "disk
It is clear your hard disk has developed errors.
Let the disk check run completely. If is stops in the middle, that shows their is a major problem with your hard disk.
If you cancel the disk checking, the computer hangs because some of the system files are already damaged due to the hard disk error.
One thing you can do is to backup everything and format the hard disk and reinstall the operating system and the software.
If the hard disk error is propagating type (i.e. the amount damaged keeps increasing), you will have to reinstall the OS every 2 to 4 weeks.
In this case it is better to replace your hard disk.
Sep 11, 2011 | Acer TravelMate 290 Notebook
I bought an Imation Apollo II (320GB) and had it formatted for my macbook in the store I bought it. It has worked fine up until 2 days ago. Now, when plugged in, it says only 'the disk you inserted was...
Hello barry_carrot,
I work for Imation and we would advise you to try the following option:
restart to your Macbook without the external drive attached.
Open your Disk Utility (in your Applications/Utilites folder).
Plug in your hard drive.
If the drive shows up in the list in the Disk Utility First Aid window, click on the drive, and then click on Repair Disk. If the process repairs anything, run the same Repair Disk a second time to see that it runs with no problems found. If some other error comes up, or it won't repair a problem found, then I would recommend moving this drive to a PC, and trying a repair tool through Windows.
Note: if you see the "repair" option grayed out, Going back to Disk Utility - (you won't be able to select Verify/Repair Disk Permissions), but Verify or Repair Disk should be available if you click on the device (the entry showing the manufacturer's info for your external drive).
If that doesn't help you, please contact the Imation product support department at the phone number 1-800-351-8186 option 2.
Jul 20, 2011 | Computers & Internet
Remove write protection
what you need to do is connect your usb drive, then open a command prompt window (Programs->accesories) and in this window type:
diskpart.exe
and press enter
you will be presented with another window similar to the first. In this new window type:
list volume
and press enter
this will show you a list of all drives connected to your machine.
Next type:
select volume *
where * is the volume number of the required drive listed in the list volume section.
and press enter
This will select the drive for the change you are about to make.
type:
detail volume
and press enter
this will list all of the attributes to do with the selected drive, you should see in there that the disk is write protected.
next type:
ATTRIBUTES DISK CLEAR READONLY
and press enter. Once the window has finished what it's doing you can close all of the command prompt windows and your disk should be ready to use again.
Hope this wasn't too long winded and has been of some use to you.
May 06, 2011 | Computers & Internet
I want to install the printer on my laptop
Hi, Please follow the instructions to install it If you have a disk for your printer then put the disk in It would automatically pop up a window to install the printer (If doesn't, go to My Computer>CD/DVD drive and at the bottom most of the window, you would find an Hp Icon with the name Setup Click on setup and it would show you the installation window, Follow the instructions after you click on install, it would show you a window saying please allow all hp processes... click next on that window After that it would show you the window to Agree the terms and conditions, so please select 'I Accept and click on Next' If in between any window showsjust keep clicking Next, Until you don't get to the point which says connect the USB cable Once you would connect the Usb cable it would show up a green bar, Once it completes please click on next And then a Windows would come up saying 'Congratutalations!! Your printer has been installed completely' Click on Finish and your printer is setup If you don't have the software CD, click on the link below to download the software
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3645100&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Select the operating system that you are using and click on next It would show you the drivers below Click on the (+) sign next to drivers and download the Full feature softwares and drivers Once you click on download, a window would pop up asking Run or save Click on save and the window the pops up Select Desktop on that and click on save Then once its downloaded, click on the icon that shows on the desktop for downloaded software and extract it Once its extracted, It would show up the installation screen. Then you can follow the instruction written above
Oct 26, 2010 | HP OfficeJet J4580 All-In-One Laser...
I had to have windows reinstalled in my computer and know I am attaching my HP Deskjet printer and need assistance
Hi, Please follow the instructions to install it If you have a disk for your printer then put the disk in It would automatically pop up a window to install the printer (If doesn't, go to My Computer>CD/DVD drive and at the bottom most of the window, you would find an Hp Icon with the name Setup Click on setup and it would show you the installation window, Follow the instructions after you click on install, it would show you a window saying please allow all hp processes... click next on that window After that it would show you the window to Agree the terms and conditions, so please select 'I Accept and click on Next' If in between any window showsjust keep clicking Next, Until you don't get to the point which says connect the USB cable Once you would connect the Usb cable it would show up a green bar, Once it completes please click on next And then a Windows would come up saying 'Congratutalations!! Your printer has been installed completely' Click on Finish and your printer is setup If you don't have the software CD, click on the link below to download the software http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=372335&lc=en&cc=us&dlc=en&lang=en&cc=us Select the operating system that you are using and click on next It would show you the drivers below Click on the (+) sign next to drivers and download the Full feature softwares and drivers Once you click on download, a window would pop up asking Run or save Click on save and the window the pops up Select Desktop on that and click on save Then once its downloaded, click on the icon that shows on the desktop for downloaded software and extract it Once its extracted, It would show up the installation screen. Then you can follow the instruction written above
Oct 25, 2010 | HP DeskJet 3745 Printer
How do I reformat my G Drive mobile USB for using it on windows 7
you dont need to re-format unless it was set for some wierd OS like MAC or linux
But you can use the device manager from within win 7
go to control panel then administrative tools then computer management then disk management and it shgould show up in there and then select it and format it from there
Aug 07, 2010 | G-Technology G-DRIVE (90801201) 250 GB...
A window appears on my screen that indicates that I can't close.
Why don't you just remove the application and try to reinstall it again. It worked for me,
Jan 13, 2009 | Logitech Webcam
IMATION Super Disk. MODEL No SD USB M3. SERIAL NO 10152 16632A
Define "no tworks"?
When you insert a disk, do you hear it spinning?
If it does spin, does it transfer any data from the disk into the computer?
Aug 21, 2008 | Imation (01946) External Floppy Drive
"a service installation section in this INF is invalid"
If the player is showing up in your Windows' Device Manager under "portable devices" with a yellow "!":
1.) Right-click the yellow "!" and choose "update driver".
2.) When given the option to connect to Windows Update, choose "no, not this time" and click next.
3.) Choose "Install from a specific location (advanced)" and click next.
4.) Choose "Don't search. I will choose the driver to install" and click next.
5.) Click the "Have Disk" button. Browse to C:\Windows\inf and choose the file marked "wpdmtp.inf"
I can't believe the generic players have such crappy support when so many people have this problem! I think the Windows file problem might be caused by "compressing old files" when you do a disk cleanup.
Oct 15, 2007 | RCA OPAL M4001 MP3 Player
77 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
