Question about Maytag MED6600TQ Dryer
Dryer won't start, The door is closed, the drum will turn by hand and I feel the belt is attached. All the light work on the panel. If the lights work on the panel, could it still be the fuse? or the control panel
    Problem Solver:
  • 13 Answers
Could be the capacitor on the motor or could be the switch on the door.
Posted on Nov 16, 2013
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Posted on Nov 05, 2008
SOURCE: Maytag Electric Dryer - Control panel doesn't light unless door is open
I fixed my own problem...I took the extra 4th wire(green) and attached it to the dryer body...There is a screw with the word ground stamped into the metal above it. This is right next to the panal where the cord goes into. I just unscrewed it and put my cable there and the dryer works perfect.....These things need to have a detailed diagram on the dryer....
Posted on Feb 15, 2009
SOURCE: My maytag neptune dryer won't start. The control
control panel dont light up wont start
Posted on Feb 03, 2013
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
My Whirlpool Electric Dryer GEW9250PWO .
Feb 22, 2015 | Whirlpool Dryers
Hotpoint Aquarius ctd40 reverse action tumble dryer all panel lights flashing on and off intermittently, can't do anything?? Help!!!
Oct 16, 2014 | Dryers
Why won't my dryer turn on?
May 15, 2014 | Kenmore HE5 Electric Dryer
Dryer won't heat up and light bulb turns on then off when door is opened.
Does the drum spin when you shut the door and start the dryer if so it wouldn't be a bad door switch. 1st. thing I would check would be the igniter with front kick panel off dryer it's located at the bottom right hand outer side of drum in the burner duct. here's how you check it with door shut start dryer and look for a orange glow from the igniter if no glow it's a bad igniter if it's not the igniter it could be a thermostat or a flame switch check these things if need more help I'll be glad to help.
Feb 25, 2013 | Dryers
Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | LG Dryers
Heatman - you comments are always dead on. You've help me extend the life of my dry twice. My current problem is this: When starting the dryer, the drum will not rotate, and the motor makes an...
it could be the extra weight on the motor and the motor is bad,try this,open the door,push the door switch in with one hand and spin the drum with the other hand and have someone push the start button,if it runs and most of the time it does because you're helping it along you need a new motor.one more thing,if the filter is in front,remove the duct that the lint filter slides into and spin the drum,if the blower wheel moves with the drum you have a bad motor,if it doesn't you have something stuck in the blower wheel and it jams up the motor because it's attached to the motor shaft.
Jun 10, 2011 | Dryers
The dryer is plugged in and the circuts seem to work however the dryer is making a humming noise but it will not turn on fully.
what do you mean it won't fully turn on?do you mean the motor won't run because usually when it humms you either have a bad motor or something is jammed and stopped the motor from spinning.try this,open the door,with one hand hold the door switch in and with the other hand spin the drum,have someone else push the start button while you do this,if it starts the motor is bad,if you can't spin the drum something could be stuck in the blower wheel or the belt broke and could of jammed up the motor but it sounds like you have a bad motor.let me know what you find and next time send the brand name and model number.
May 04, 2011 | Dryers
Good Afternoon Modle DV219AG Gas Dryer: The dryer will not start. We push the start botton the drum does not turn. After about 3 seconds I hear a click. (electric circuit type click sound) All of the...
heatman101
Mar 21, 2011 | Samsung DV219AG Dryer
GE model DQSR483EE1WW. This is what I know so far: the switch on the door works so it shouldnt be that safety, it is getting power because the light work and the timer at least buzzes like its working,...
Try looking for a broken belt. (electrical interlock prevents starting with broken belt) Disconnect power, open door, remove two phillips screws which go from top of door opening into dryer top. Swing top up and back. If belt not present going around drum, that's your problem. Remove one screw from side panel to front panel on each side (near top) and lift front panel forward and off the bottom pegs. Set the front panel to the side (leaving door switch wires attached) so you can slip new belt around drum. Reach under drum to put belt WE12M29 around drive pulley and around tensioning pulley. (grooved side of belt touches drum) Put front back on dryer and manually rotate drum a couple revolutions to make sure belt does not come off before closing up top and reconnecting power.
Dec 24, 2009 | Dryers
Maytag MED6600TQ Dryer Logo
51 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
