Question about Jenn-Air JJW8530C Expressions Collection Dual Single Oven
Neff single oven burns underside of food before cooked
Oven overheats would it be faulty thermestat
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Check tthermostat
Posted on Nov 22, 2013
Tip
Common heating faults with Neff B1644 single oven
For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Neff fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
on Jan 19, 2010 | Neff B1644 Electric Single Oven
Hi got a NEFF B1691 oven. Thing is the oven light, element and fan keep switching off during cooking is this correct functionality - if not what could be wrong? The temperature display remains functioning...
There does seem to be a fault, as the fan should run continuously even when the element goes off at the required temperature setting, and the light should atay on as well.
It suggests to me that there is a fault with the oven thermostat, or it is wired incorrectly.
Dec 21, 2010 | Neff B1691 Single circotherm super...
Oven door to hot too the touch.
check that the thermostat is working correctly.if food is cooking to quickly or burning then stat could be faulty
Aug 05, 2009 | Neff U1421 Double circotherm Electric Oven
Tip
Common heating faults with Neff B1476 single oven
on Jan 19, 2010 | Neff B1476 Pyrolytic Stainless Steel...
Tip
Common heating faults with Neff B1691 single oven
on Jan 19, 2010 | Neff B1691 Single circotherm super...
Tip
Common heating faults with Neff B1451 single oven
on Jan 19, 2010 | Neff B1451 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1432 single oven
on Jan 19, 2010 | Neff B1432 Single circotherm plus Electric...
Tip
Common heating faults with Neff B1428 single oven
on Jan 19, 2010 | Neff B1428 Nostalgic Single circotherm...
Tip
Common heating faults with Neff B1641 Single electric oven
on Jan 19, 2010 | Neff B1641 Single circotherm super...
Tip
Common heating faults with Neff B1421 Electric Single Oven
on Jan 19, 2010 | Neff B1421 Electric Single Oven
Jenn-Air JJW8530C Expressions Collection Dual Single Oven Logo
54 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
