Question about Samsung WF337AA Front Load Washer
Washer keeps flashing LE - Samsung WF337AA Front Load Washer
  • Samsung Master
  • 3,051 Answers
Hello there and welcome to fixya
this could be a possiability of several things but please try this first
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine due to using too much soap.
Overloading the wash with too much laundry may also cause the LE error code.
And finally , a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened.
Posted on Nov 16, 2013
Lg wm2101hw code le
Press "end of cycle" for 3 seconds or till the flashing goes off . Plug off the wall. Code can be an indication of several issues. The most common cause is over sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Click helped if helped.........
Mar 15, 2013 | LG WM2101HW 4.0 cu.ft. Washer
It says LE and will not start washing
LE means your motor or hall sensor is faulty. if u r confident please reply back and i will guide u thru how to find exact fault. 95% of the time it is the hall sensor.
Apr 14, 2010 | LG WM-2277HW Front Load Washer
Washer won't work
le means your hall sensor on motor is faulty. if u r confident change sensor.or phone service companys 4 price on hall sensor replacement, or reply back 4 more help
Mar 27, 2010 | LG WM2277H Front Load Washer
I have a LG WASHER,FRONT LOADER WM0532HW KEEPS FLASHING LE,THE DRUM WILL NOT ROTATE
LE stands for locked motor error.  The first thing you should try is simply unplugging the machine for 10 minutes.  If the problem continues the next most likely cause is the hall sensor.  To get to the hall sensor remove the back cover, then remove the wheel that is attched to the drum.  Undre that wheel if the stator (motor).  At the bottom there is a sensor that spans about three of the windings.  This is the hall sensor.  It is not very expensive.  If neither of those work you will need to replace the Stator (motor)
Oct 22, 2009 | LG WM-2277HW Front Load Washer
LE code flashing on WM1812CW
LE code is overload on motor. This unit actually has a magneto and stator. This is what needs to be replaced. Usually find a magnet cracked.
Aug 27, 2009 | LG WM-1832C Front Load Washer
Washer
Greetings jannd,
The message "LE" can indicate that the thermal overload protection circuit in the motor has been tripped. The remedy for this can be to allow the washer to stand for 30 minutes to allow the motor to cool, then restart the cycle. If the LE error code still appears, unplug the washer and call for service. Keep in mind that this unit carries a 7 year warranty on the motor also.
I hope this helps!
Best regards,
Dorothy
Go Ahead. Use Us.
May 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE Code on control panel
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Dec 31, 2007 | Washing Machines
LE code
LE error is a locked rotor you need to have your hall sensor on the stator or better yet just have the whole stator replaced which comes with the sensor on it (P.S. the stator is part of the motor and has a 5 year warranty)
Oct 30, 2007 | LG WM-1832C Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
Samsung WF337AA Front Load Washer Logo
89 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
