Question about Dryers
Hunter 44360 I installed the 44360 in 2007. It worked fine until Feb. 2013 when I noticed the A/C was running but I had not switched back from heat. I came inside and the furnace was running (and heating the house). I switched to 'cool', shut off the furnace and did nothing else. Now I want to switch to 'heat'. For a temporary fix I will pull the 44360 off the wall and disconnect the A/C. What are the possible causes and solutions? The A/C is about 8 yrs old and the furnace is 25+. Both were installed before I bought the house.
  • 63 Answers
Sounds like it is time to update your equipment for economy purposes as well as safety reasons, I was a CORGI registered heating engineer before I retired. Be advised.
Good luck
Posted on Nov 16, 2013
    New Friend:
    Problem Solver:
  • 7 Answers
Check your termostat that is not working well
  • 52 Answers
SOURCE: Hunter 44630 thermostat
Here is a link that will have wiring diagram it is for a similar model hunter. Also check your dip switch on the back of the stat to ensure it is set for gas (HG) or electric heat (HE) depending on your type of unit. Good Luck. Rule of thumb for most four wire systems is RED (power to stat) Yellow (Cooling) Green (Fan) White (heat)
Posted on Jan 29, 2008
  • 833 Answers
SOURCE: Hunter 44360 thermostat wiring
If you don't have the wiring information, go here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf and see page 10.
If you're still having problems, go down to the furnace room and find the piece of equipment that you're wiring to.  See where the wires came from, transpose that to the information above.  Note: the wiring from the relay box should be 24 volts which is safe to handle.  Wiring inside the relay box may be 110 or more volts which is not!!!  Cut power before opening relay boxes.
As far as heater running continuously, be sure of your wiring.  You may have the gas relay lead and the fan lead reversed.  Determine if you've set the switch options for your type of heater correctly!!!  Do you hear the relay clicking in and out at or near the room temp when you change the setpoint?  If not, the unit may be defective.
Posted on Nov 15, 2008
SOURCE: Hunter 44360 problem
I have the same Hunter 44360 programmable thermostat and just recently turned on the heat. I had left the house and came back to find that it was 88 degrees after a couple of hours. I called tech support with little luck. However, if you pulll off the face of the thermostat and look on the back panel, there's a switch that can be moved to "std" or "hp". Mine was in the "hp" position and the plate that attaches to the wall read, "put in hp position if you have a single stage heat pump". So i switched it over to the "std" position and, like magic, the thermostat is working beautifully to heat my home. Also, i have a multiple stage heat pump.
hope this helps someone,
rich
Posted on Nov 18, 2008
Benimur
  • 6966 Answers
SOURCE: Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Posted on Jan 01, 2009
SOURCE: hunter fan 44360 won't turn my furnace on
I am having the same issue the fan turns on when you turn it on but it is just a fan with room temperature blowing out.
Posted on Jan 04, 2010
I have a Hunter Thermostat 44360 7 day Programable and I want to cancel all programs and just use it manually amy help?????
There should be a tiny unmarked hole in the front of the thermostat....if so, the thermostat 'reset' micro-switch should be under that hole. Gently stick a thin toothpick inside to depress the switch and get ready to operate it manually.
If there is no hole, separate the thermostat from its sub-base and look closely at the sub-base for a reset button.
Apr 13, 2015 | Hunter 44360 7-Day Programmable Digital...
Heating Model 44360
you should have a 'hold temp' option on your remote, it should then stay at the set temp until you change it
Mar 01, 2014 | Hunter 30124 Air Conditioner
I have a Ruud air handler and i'm trying to use a
The 44360 tstat can be used for single stage Heat pump use only. Unless you are in an environment that has greater than 40 degF outdoor temperatures year-round, you will want to return that tstat and obtain a multi-stage Heat Pump tstat. The standard system is 2-stage......1st stage is Heat Pump Compressor and 2nd stage is the backup electric heat.
Hope this helps. Good Luck. :-)
http://www.hunterfan.com/uploadedFiles/Support/Downloads/42710.pdf?n=149
Feb 21, 2010 | Heating & Cooling
I need a new manual for my 44360 Hunter programmable thermostat.
Try this URL. Should be able to download it for free.
http://homeappliance.manualsonline.com/manuals/mfg/hunter/44360.html
Click on the above link. If that doesn't work for you, copy and paste it into your browser's URL line.
Oct 13, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hunter fan 44360 won't turn my furnace on
List of things to check:
Are the batteries good?
Is the system switch set to heat, and not cool?
Does the fan come on when you set the fan switch to ON?
If none of these things seem to be the problem, call hunter fan tech support at 1-888-830-1326
Oct 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Feb 15, 2009 | Ruud UBHC Air Conditioner
Nov 14, 2008 | Hunter Fan Company 5/1/1 Programmable...
You probably have one of the wires reversed or have the options set incorrectly as to what type of heater you have.  Check your instructions here: http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/42710.pdf
Oct 29, 2008 | Hunter Fan Company 5/1/1 Programmable...
OMG! has anyone came up with a solution? I have the same problem as mlc3530b
Mar 08, 2008 | Hunter Fan Company 5/1/1 Programmable...
Dryers Logo
82 people viewed this question
Top Dryers Experts
