Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
Can't get my working lights to come on
I have a 2305 Johne Deere utility tractor. I can't get the working lamps to come on. When I turn on the turn signal I can hear them, but the lights don't work. Fuses and bulbs are good. I have voltage to the fuse box.
  • 51 Answers
If you have power to the fuse box, measure with a multimeter to see how much you have from the battery, then to the fuse box... Then see how much leaving the fuse box, if there isn't any power leaving the fuse box,,, you have a faulty fuse box or a possible bad connection (ground) if you have power check the relays, often you relays go bad, you'll hear them flicker but the don't actual make the connection to give voltage to the lights... Also you can test the voltage at the light bulb socket with the power on and switch on with a multimeter..
Posted on Nov 18, 2013
  • 279 Answers
SOURCE: john deere 850 compact
There is a switch under the seat. Just to test and not to run, you can take a jumper cable and go around the switch. If you find this works, go get a new swtich. It is very important for safety...Good luck...Lee
Posted on Sep 04, 2009
mickey813
  • 472 Answers
SOURCE: Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Posted on Oct 14, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: need the pto to work on a 6300 john deere tractor
If you have tried a new sensor and a new switch the the next step is to replace the pto solenoid valve.If that proves fruitless then the b.c.u.needs to be replaced or bypassed.The solenoid valve will cure your problem 90% of the time.If that does not work,let me know,i can tell you how to by-pass the b.c.u..
Posted on May 08, 2010
Solenoid 2305 john deere
When bolting it on, be sure good and clean. Its your ground for solenoid.
Jul 26, 2014 | John Deere Garden
2320 johne deere diesel tractor cranks over but won't start
May have air in the injection system. Open the drains leading to the injectors making sure all the air has been removed then retighten and it make a few extra turns before it will start.
Mar 14, 2014 | John Deere 420,1020,2010,2020,2510,2520...
2320 johne deere disiel tractor cranks over but won't start
check fuel filter first and that fuel pump works by openig at fuel pump and pushing fuel out just short of injection pump-- if no fuel pushes out prime fuel system by pushing air into fuel tank or using a in line hand fuel pump--- fill tank on tractor so that fuel is above injector pump also helps probably a prime problem
2320 johne deere desiel tractor cranks over but won't start
Did you bleed the air out of filters and then crack injector lines?
2320 johne deere desil tractor cranks over but won't start
Crack the fuel line going to the injector pump, only crack it don't take it
completely off, now see if fuel is coming out while cranking
the engine. It's best to have another person do the cranking while you check for the fuel. If no fuel come out, you have a blockage somewhere between the fuel tank and fuel filters
Let me know how this works out.
Mar 14, 2014 | Cover My Tractor Tractor Cab-Enclosure for...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
99 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
