Question about Kitchen Ranges
Automatic fan I have a Jenn-aire JDS9860AAP. the left side of the range was originally a grill, but we replaced it with a burner insert. Whenever we turn that side on a high fan starts, sucking all the heat away. How do I turn off the feature that automatically turns the fan on hi when using that side of the range?
    New Friend:
    Problem Solver:
  • 7 Answers
THIER IS MISSING A SEPERATOR THAT WILL STOP SUCKING FROM UNDER AND WILL TAKE TOP AIR
Posted on Nov 16, 2013
SOURCE: will not cook properly with downdraft vent on. JDS9860AAP Range
You can purchase a 2 burner cartridge. However, the problem I'm having with that is the gas is too high and is unable to cook anything on low.
Posted on Feb 13, 2008
yalmer
  • 549 Answers
SOURCE: Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Posted on Mar 17, 2008
SOURCE: clock assembly
my automatic cleaning setting in my oven will not heat up. I set "clean" on both dials and put the lock on, the fan comes on but no heat. Is there a certain system to turning it all on and the timer so it will work?
Posted on Jun 02, 2008
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Posted on Jan 29, 2009
SOURCE: How to replace spark igniter - Jenn-Air SEG196 gas-electric range
took off the knob to the ignition system to clean and spray got onto the ignition under the dial and now the two front burners won't ignite unless I turn on one of the functional back burners then turn on the front burner. How do I repair this?
Posted on Oct 11, 2009
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
www.applianceblog.com/.../12231-Jenn-Air-Oven-SVD48600B-continu...
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from www.applianceblog.com
Nov 21, 2015 | Jenn-Air Kitchen Ranges
An older jenn air grill range model # S125- the left burner does not work front or back and the light stays on
Replace the switch that controls one of the two burners. One switch is bad. Look also for a blown fuse. if present.
Chances are one bad element had shorted out the switch (now stays lit) and also took out one fuse.
Oct 20, 2013 | Jenn-Air Kitchen Ranges
Jenn-air dual fuel jds9860aap intermitently display blinks like it lost power, reset and it will happen again. originally started with a f9 code that has not reoccured. If the oven is on, it will shut off...
Sounds as if you have a bad ground or nuetral wire connection. Unplug and check the connections to your control assembly and the pigtail on the range. I have also seen displays on Jenn-air go bad as well.Replace the clock assembly.
Apr 19, 2011 | Jenn-Air JDS9860A Dual Fuel (Electric and...
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Oct 07, 2010 | Jenn-Air Kitchen Ranges
Jenn-Air model svd48600. Gas stove top, electric oven. Why would the exhaust fan turn itself on whe either of the left burners is lit.
The switch for the optional grill attachment is activating...pull the tray/pan on the left side that holds the two burner grates toward the front...it should shut off. To correct the problem permanently, you'll need to adjust the position of the switch. The switch gets lose over time and slides on its mount until it gets out of range. The purpose of the switch is to activate the blower continuously when using the optional grill accessory. When you remove the left-side grates and the tray/pan the grates set in...you'll notice a protruding piece of metal on the front of tray/pan that fits into a hole in the cavity where the tray sits. Inside that hole is the switch that is out of position. Getting at the switch to adjust its position is not difficult, but you need to remove the upper front panel...KLS
Dec 13, 2009 | Jenn-Air Kitchen Ranges
Jenn-Air grill half burner issue
Re: only one side lighting, it is a problem with the cross over **** that carries the flame from one side of the burner to the other. It is located at the rear bottom of the burner and is probably clogged. Wire brush them to clean; failing that, replace with new ones and keep the new ones cleaned with a wire brush regularly.
May 31, 2008 | Grilling
Will not cook properly with downdraft vent on. JDS9860AAP Range
Jan 03, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Exhaust fan comes on when burner turned on
The left side is set for your grill. There is apparently a switch under the left side top / front of the cooktop. The aeration tray has a prong on one end that fits into a hole in the front end of the burner basin and activates the switch which stops the fan from coming on when using the burners and allows the fan to run when using the grill. Try switching sides with the aeration trays as one might make better contact than the other.
Dec 01, 2007 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
