Question about D-Link Computers & Internet
Plug dangle my dlink does not reboot after it is plugged out, it show the same light display when plugged in again, which does .
  • 44 Answers
The router keeps it settings when it is unplugged. You have to factory reset it. Locate the reset button on the back and while plugged in, press and hold the reset button for 10 to 15 seconds. After you release the reset button the router will reboot to factory setting.
Posted on Feb 04, 2014
My Packard bell tj65 won't show toolbar
May be OS miss. You can unplug your RAM and then plug it again then try it again. If it display same thing then recover your operating system from system reboot system.
Thank you
Sep 07, 2016 | Packard Bell Easynote Tj61 Windows 7 Hdmi...
I have a dlink dir600. My problem is when i turn it on only power light glowing remaing not responding. Try reboot by click and hold the restart button at the back to use restore factory but no use it wont...
First reboot your modem(NOT the router), unplug for ten seconds and plug back in, wait til everything comes on. Now unplug the router, wait ten seconds and plug it back in. If it still does the same thing, reboot by holding the reset button down for 10 seconds and see if it restores to factory settings. If still no luck then there may be an issue with the router.
Aug 06, 2011 | D-Link DIR-615 Wireless Router
We had a power outage. Everything is back working expect I cannot connet to the internet. My cable company has reset the modeum and when I plug directly into my computer its fine, however when I plug...
First check to make sure you have all the light on the Dlink router lighting up (i.e. power, internet, ethernet, ect). Weather the lights are good or not, check your cables and make sure they are secure. If all the light are proper, then unplug the router for a few seconds then plug it back in. Once all the lights are on try again. If you are using wireless, plug in wired (ethernet cable) to the router. Depending on your OS and settings, you should see in the lower right hand corner a computer icon. If this has a red X on it, the router is not providing a signal to the computer. If everything looks good wired, try the internet again.
If the lights are not correct on the router and checking the cables did not fix the issue, you most likely have a problem with the router its self.
I hope this helps, if not comeback with more information (i.e. what lights are on the router, the IP address the router is giving the computer, wired works but wireless does not, the more information the better).
Jul 22, 2011 | Computers & Internet
My dlink router dir-600 was purchased only last month. It was all working well until 3 days ago...the light in wireless icon and other LAN all stopped. Only power and Globe lights were Orange... no...
If you have ethernet cable, plug one end of cable into in available slot of router (LAN) and other end ont your laptop to see if you can get out Internet that way. If not, turn off you router, wait for a minute and turn it back on. If it works after the reboot, try wireless again to see if it works. Most of time, router just needs to be rebooted.
thanks
May 13, 2011 | D-Link DIR-615 Wireless Router
Car battery always going flat!
just a spare wire i think for a different model with the same wiring loom ,try a new alternator and not a scrappy yard one
May 16, 2010 | 1986 Ford Crown Victoria
Same problem, COD for PS3 only works with 2310 on reboot
just got off the phone with dlink (my 2310 is dead lights 1-4 always on the sec you plug it in.)
The correct reset procedure is push reset button for 10 sec unplug power do not release the reset button wait 10 sec more. next plug in the power THEN release the rest button. hope this helps
Jul 04, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Iam having an issue with the dlink router , getting 0.0.0.0 ip address for wan
Hi, first establish that the wires are plugged in to the correct ports, WAN port on the back of the router is in the internet port on the ADSL (assuming that is what your using).reboot the ADSL modem and wait for the light to settle, the link light should be solid. The ethernet light does not need to be solid, and the Act or activity light should be blinking, Now go to the command prompt and type in
> ipconfig /all. you should get a WAN ip. Otherwise, check if your service provider needs the MAC address of the router to establish it on the network...Telus used to need this. If this does not work, take the wire from your computer and plug it in directly to the back of the modem, this should get an WAN IP so you know that the router may need a bit of tweeking and a reboot of the hardware may be in order to sync everthing up again,,goodluck
Jan 06, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
No Cols - Temperature Controls do not respond - LED display shows a dash "-"
pencj,
My honest answer is that I have seen this before and in most cases the board works properly after the reboot.
Although you may not have lost power, you may have gotten a voltage spike. I would cancel the service man coming out, (I am a working service man myself) he probably will give you two options. #1 Wait to see if this happens again and if it does happen again soon, the board should be replaced. #2 replace the board now.
My suggestion is to soon go purchase a surge suppressor to plug into. This does not need to be a power strip style. A good quality suppressor that only has one or 2 plug in's or plugs directly into the wall receptacle should do fine. Your refrigerators maximum amp draw is listed on the model # sticker inside the refrigerator compartment.
I hope this helps, supertechks
Jan 26, 2008 | Amana SCRATCH&DENT 25 Cu. Ft. French Doors...
DLINK Router
kmkm:
Is this the WAN light you are talking about or the power light?
The WAN light blinks to show you connection with your client computers. Its ok.
If its the power light then un plug router completly and plug it back in check if does the same thing again? If yes then some hardware issue exist and the router needs to be replaced.
Hope that helped!
Dec 07, 2007 | Acer D-Link 2.4GHz Wireless Router 802.11b...
Monitor problem
Check the cable wiring make sure all is plugged up right, If you have rebooted and it comes on ok than its the power cord. Remove and re-plug again
Nov 29, 2007 | HP Pavilion F1503 15" LCD Flat Panel...
Computers & Internet Logo
138 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
