Question about Smart Pulse Livescribe pen
Livescribe OLED is very dim
In a dark room you can see the battery is loaded
Display is dim on my sony hi-md recorder mz-m100, how can i fix that?
1) Make sure the battery is all charged up.
2) Live with it. Seriously. It will cost you $100+ to replace the display.
Nov 15, 2014 | Sony Mz-m100 Hi Md Minidisc...
My screeen on livescribe 2GB pen does not work. Has been sitting idle for 1 year.
Welcome to Livescribe. The OLED has 'decomposed' sotosay.
It was either the display or battery that would fail. The only option I've seen thus far is buy a new one.
Jun 09, 2014 | Smart Pulse Livescribe pen
How to keep the radio light on?
The sensor behind the plastic readout window needs to be exposed to a sufficient amount of light to alter the display brightness from dark room mode to bright room mode (dimmed display, bright display). Be sure sufficient light falls on the digital readout display when desiring the display to be at its bright mode setting.
Apr 26, 2014 | Bose Wave Radio Am/fm Awr1-1w Remote...
I have a Zen V plus , the screen has become really dark I can barley read it . what should I do?
Bad news. The Zen V Plus is known for screen problems - early warning signs include screen discoloration, lines on the screen or dimming. Eventually, the screen will go black.
Possible reasons include poorly-mounted screens, short life of OLED displays, and susceptibility of screens to damage from moisture.
Best bet for a replacement screen is buying a scrapped Zen V Plus on eBay. Here's a great guide to taking apart your Zen.
Disassembly of Zen Plus
Sep 27, 2013 | Creative Labs ZEN V Plus MP3 Player
Picture is too dark
you might have a special setting on the tv. not just color setting, more like brilliant, or your case a dim mode, try different menu settings. my sony dims when no one is in the room for like 5 minutes.
Dec 20, 2011 | Samsung Televison & Video
Monitor dims when we turn lights off in room.
You need to give a more detailed description of the problem.
The LG 47LH90 is an LED backlit TV with 'local dimming' technology. This means that there are lots of white LEDs behind the screen and these can be controlled in groups to allow localised areas of the screen to be dimmed to produce better contrast between light and dark. It is very likely that when the room is dark, this local dimming is more noticeable. The actual individual LEDs cannot be controlled and so the area that is dimmed will generally be greater than the area that is required to be dark 'blooming effect'. In addition, LED backlit displays only maintain their contrast through a tight viewing angle. If you sit too farto the right or left, then light from non-dimmed LEDs will leak through and the screen will look lighter.
In short, there may not be any fault with your TV.
Jul 12, 2011 | LG 47LH90 47 in. HDTV LCD
Can see what is on tv but is really dark have to turn lights down to see it.
How old is your bulb? If it's got more than 1000 hours, it may just be getting dim and needs to be replaced.
I need dark curtains in my living room to view movies, you just can't watch anything in a bright room with this unit.
Oct 11, 2009 | Sony VPL-VW50 Projector
Dark picture image, dosen't respond to briteness control
are you able to see the picture in a dark room ? does it appear bright enough then ? if so the lights behind your screen have dimmed or gone out completely. this may just be the power supply for the lights or your lcd panel may need to be replaced
Nov 19, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Remote control sensor doesn't work when the room is dark.
its probably the led in the remoter, check with a camera on a phone point the camera at the remote if its dim, that's the problem, it could also be a damaged battery in the remote.
Jun 18, 2017 | Televison & Video
Smart Pulse Livescribe pen Logo
267 people viewed this question
Top Smart Computers & Internet Experts
Computer Links
NOEL
NOEL
Pcm2048
Are you a Smart Computer and Internet Expert? Answer questions, earn points and help others
