Question about Royal Office Equipment & Supplies
Shift lock stuck on royal quiet deluxe
My shift lock is stuck on the Royal Quiet Deluxe and I cannot figure out where to lube or fix it.
    Problem Solver:
  • 15 Answers
Pull off the plastic cap and you should be able to see where it is stuck.
Posted on Nov 17, 2013
2 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: Shift lock stuck on my Royal Quiet Deluxe
Probably the lock spring is broken or just sticky. Flip it on it's back and look closely at the shift lock latch. You should be able to easily see the problem. Fix the spring or lube the latch.
Posted on Dec 30, 2009
The peice of my typewriter that is supposed to move the paper tothe left as you type doesnt move?
It's either in the carriage lock position, just check if it's locked in place.
The other reason may be that the return spring has broken. Easy to replace & is repairable sometimes.
Jul 18, 2014 | TYPE B 1957 Royal Quiet DeLuxe Typewriter
Quiet deluxe typewriter
This is called motion adjustment
I assume the "segment" or the type faces go up and down when you shift? otherwise the "platen" where paper goes goes up and down either way there are a bump stop that is adjustable. usually with a flat blade screwdriver and a 5/16" wrench. there will be a bump stop on each side that must be adjusted equally however only one may be loose causing the problem. but first you should check the linkage for bends or binds shift lock should hold it to the maximum against the stops. Let me know
David Hughes been working on TW since 1975
Jun 01, 2017 | Royal 1940s Antique "Quiet Deluxe"...
Shift Key Problem , Royal Quiet Deluxe
There is a carriage shifting screw on both sides of the typewriter. You will recognize this because it is a screw that has a big bump head with felt on it. It is being hit when you hit that shift lever. You will have to loosen the securing nut first before adjusting.
Nov 17, 2013 | Royal Office Equipment & Supplies
The ivory colored plastic turning knob on the right side (doubt it matters) that turns the barrel so you can insert paper (you can still turn it without, there's a small visible circular piece of steel...
Checked out eBay...
Right here in Sun City California... for PARTS
or REPAIR... (ONE of about 70 machines available)..
VINTAGE ROYAL QUIET DELUXE PORTABLE TYPEWRITER FOR PARTS REPAIR MADE IN...
Being a collector of old car parts (myself) if figure
there were plenty of collectors of Royal typewrters...
Sure enough..!! (hope this inspires).
Carnac the Magnificent
Jan 09, 2018 | Royal Quiet De Luxe Portable Typewrite...
2005 Yamaha Royal Star Touring Deluxe clutch whine
Hi, Rcihvac I would love to help you with your engine or chassis noise but I just loaned my brand new pair of listening ears to your local dealer's chief technician so he could take your bike for a test ride and give you his professional opinion and estimate about your noise and repair cost. If you are a little short on "DRACHMA" and a Dealership is not on your list of fun places to visit then perhaps the list below will help soothe your worried mind so you can make an informed decision.
1. Bearings---SCREECH
2. Belts---CHIRP
3. Brake Rotors---BUZZ
4. Cam Chains---CLICKIT
5. Clutches---CHATTER
6. Cylinders---PING
7. Fairing Panels---WHISTLE
8. Fenders---SCRAPE
9. Fronk Forks---Plunk
10. Fuel pumps---WHIRR
11. Gears---WHINE
12. Head Gasket---HISS
13. Hydraulic Lifters---TAP
14. Instrument Clusters---BUZZING
15. Kick Starter---GRINDS
16. Pistons---SLAP
17. Power Valves---CLINK& RATTLE
18. Radiators---GURGLE
19. Rear Chains---RATTLE
20. Rear Shocks---SQUEAK
21. Relays---CLICK&BUZZ
22. Shaft Drives---WHIRR
23. Shifting Trans---CLUNK
24. Solid Lifters---TICK
25. Speedometers---bzzz
26. Starters---CLICK
27. Rods Go---KNOCK-KNOCK---who's there, it's me "*****"
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
High Pitch Whistle Whine Transmission
Yamaha royal star tour deluxe whine
http://www.werder.ee/Manual/XVZ1300.pdf
https://www.partsfish.com/page/oem-parts-for-yamaha
YAMAHA XVZ1300A Owner Manual
Dec 31, 2017 | 2005 Yamaha Royal Star Tour Deluxe
2005 yamaha royal star. what type and how much oil for the tranny?
The Royal Star crankcase lubricates engine, transmission and wet clutch at the same time, that's why frequent oil and filter changes are recommended. Use a high-quality multi-grade oil, 10W-30 in cold weather and 20W-40 in hot weather is recommended by the manufacturer. AVOID ANY OIL THAT SAYS ENERGY-CONSERVING (you'll see a seal on the bottle), that type of oil has a tendency to make the clutch slip. Personally, I recommend a multi-grade synthetic - I use Shell Rotella-T (T6) synthetic 5W-40 year-round, 111,000 miles since I changed from Mobil-1 0W-40 (9,000 on the Mobil-1) ; the engine's still tight, and the transmission and clutch are quiet.
Jun 09, 2010 | 2005 Yamaha Royal Star Tour Deluxe
Dec 25, 2009 | Office Equipment & Supplies
I have an old school "Royal Quiet Deluxe" typewriter; the carriage will not move when the letter keys are pressed or when the space bar is pressed but will move to back space or to slide the carriage back...
If there is tension on the carriage when you push it to the right, the spring is not broke or the cord..then the problem would be in the escapement area..you would need a repairman to do this. if the carriage is loose, no tension then the spring is either broke or the cord is off or broke.
Either way not something easy....
Sep 29, 2009 | Royal Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
Sep 05, 2009 | Office Equipment & Supplies
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
137 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
