Question about Yamata Fy5318 Mechanical Sewing Machine
Machine is jammed, how to fix - Yamata Fy5318 Mechanical Sewing Machine
I have a brother lx 2500 sewing machine and when it jamed i opened up the bobbin area and cleaned everything but now having problems getting the casing back in
Use a mirror and make sure that the area is perfectly clean and there are no obstructions. Then make sure that the needle is all the way up to the top of its cycle and then insert the bobbin.
Sep 20, 2015 | Brother Sewing Machines
Sewing machine jam
If you mean that the needle has jammed with a build up of thread, then the only option is to cut the thread, raise the needle, if you can, and remove ALL pieces of cut thread. Sometimes if it's really jammed, you need to use a sharp knife, horizontally, to slice through the jammed thread.
The bobbin should be removed after this, and ALL traces of thread removed from all areas. Then, re-thread, re-insert bobbin, and try again.
Apr 19, 2015 | Brother Sewing Machines
How do I adjust the hook needle timing on my bernina 950?
I have a Bernina 950 sewing machine and I had a thread jam, and to remove the jam the hook came apart. Does it mean every time I have a thread jam I have to pay someone to fix the hook?
Why can I do this my self if someone will share pictures or knowledge?
Feb 28, 2015 | Bernina Sewing Machines
Cutter on speedylock
Servicing the Timing is NOT a home fix
Mar 08, 2014 | White Sewing Speedylock 1600 Mechanical...
Sewing machine jams
does it jam up on the top or bottom?? if it shows on top it is the bottom thread if it jams on the bottom it is the top thread
Oct 12, 2009 | Husqvarna Viking 1
Hello, I have bought a PFAFF 213 sewing machine with a jammed shaft. I have oiled the machine, but the needle won't move up and down. The machine is very clean inside, indicating that it has been used...
I did fix the jammed shaft - simply by applying some tenacious oil and letting it sit overnight. It is now a fully-functioning machine!
Thanks for your ear and your interest,
Cathy
Apr 03, 2008 | PfaFF Creative 7570
Jammed
ROLL THE MANUAL LEVER BACK AND FORTH WITH CONTROLLED FORCE till the needle comes out! the jamming is caused by threads tangled inside the bobbin area. rolled it with a controlled force back and forth. when the needle comes out flip your machine to where you could open the bottom part and remove/clean the threads tangled on the bobbin!
place some OIL.
Nov 19, 2007 | Singer 1116 Mechanical Sewing Machine
Yamata Fy5318 Mechanical Sewing Machine Logo
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
