Question about Mitsubishi WT-46809 46" Rear Projection Television
Power will not stay on
When I turn on the power with remote or power button, the tv clicks, the timer button turns green, and it clicks and turns off after 3 seconds.
  • 1 more comment
  • Anonymous Nov 23, 2007
    I have the same problem. srarted yesterday. While I was watching tv it would black out after a few seconds it would go on again. after half hour or so it went off allther. I took back off thought it might be dirty or have some dust not! Now I put it on green light goes on and 2 seconds goes off. What to do???
    Thank you for your help
    Ritchie
  • Anonymous Nov 29, 2007
    Same problem with me too.
    Green power light stays on for two seconds and then switches off. Prior to that I was having an issue where the colors would not converge. Definitely not a setup issue.
    Funny that these posts about the power light happened to all of us within the same timeframe.
    Thanks for any help.
    bob
  • jft1918 Dec 30, 2007
    Exact same problem. When I turn on the TV, the green timer light comes on for a couple of seconds then goes off. The TV won't power on other than this.
    Problem Solver:
I have the same problem, it is a great tv and i think would be worth fixing. Just started today. Hope we can get these bad boys fixed.
Posted on Oct 08, 2007
Same TV, same problem. I'll be watching for an answer. The dealer says it is old and outdated and not worth fixing.
Posted on Oct 07, 2007
3 Suggested Answers
  • 1153 Answers
SOURCE: Wont stay on
I can help u fix in live chat!
micromaster
  • 3614 Answers
SOURCE: Power will not stay on
A problem in a certain parts or IC's on the board. You need a support technician for him to have a test inside the equipment. All parts have to be undergo into tester device to determine which is faulty.
thanks.
Posted on Feb 23, 2008
How do I fix my Jvc the screen won't power on. When I reset it the lights on the buttons light up...but shut off right away. It has power because the red light on the bottom left corner stays lit.
JVC LT-46AM73 LCD TV Won't Turn On - YouTube
? 3:28
https://www.youtube.com/watch?v=y5j3RGUe4gM
Feb 25, 2015 - Uploaded by Awesome Things
JVC LT-46AM73 LCD TV won't turn on after power outage. ...LCD & LED TV Repair - No Image & Blank Black ScreenFlashlight Test - How to ...
JVC wont turn on - JVC - Streaming Video & TVs
www.tomsguide.com/answers/id-1677424/jvc-wont-turn.html
May 15, 2013 - JVC lcd tv will act like its turning on then the green light after 2 seconds ... wont turn on Forum; SolvedAcer Laptop V4DA2, screen won't turn on.
My Jvc Av-32F476 Tv Won't Power On, The Green On Timer Light Stays ...
www.diyforums.net/my-jvc-av-32f476-tv-wont-power-on-the-green-on-...
Dec 8, 2013 - My jvc av-32F476 tv won't power on, the green on timer light stays on and m. ... On the remote control, look for the buttons PICTURE MODE and DISPLAY, with ... My Jvc Lt24dd52j Won't Turn On The Blue Light Is Flashing But ...
Nov 1, 2014
I Have A JVC LT-42TG30J, Randomly The Tv Has Decided It ...
Aug 29, 2012
I Have No Picture On My 47 Inch On My Jvc Big Screen Just A ...
May 23, 2012
My Dynex 42" Wont Turn On Power Led Is Lit Up But It Won't C ...
May 24, 2011
More results from www.diyforums.net
Jan 18, 2016 | JVC Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
thanks.
Feb 23, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
what is the model number of your set?
Mar 09, 2008 | Televison & Video
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Wont stay on
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WT-46809 46" Rear Projection Television Logo
109 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
