Question about Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor for 56J Frame
Marathon wiring THE MOTOR IS SPINNING IN THE DIRECTION HOW DO I FIX THAT
  • 372 Answers
Are you sure? Single phase pool motors are not reversible (unless something weird happened that I can't explain). Three phase motors are reversible, but very rare in residential wiring.
Looking directly at the end of the motor shaft (where the impeller goes) it should spin counter- clockwise. Both of the power wires can be attached to either terminal; there is no "polarity".
Posted on Nov 18, 2013
  • mikadot
    mikadot Nov 18, 2013
    You can reverse any split phase motor by reversing the start winding connections inside. That is why so many wires and posts are seen where you put the wiring connections to. 220 volt motors are still split phase and can be done the same way. If it is a capacitor start induction run motor you can reverse the capacitor. Yes three phase is easier to reverse by interchanging any two line wires, but all motors can be reversed except shaded pole motors.
  • Bill Jordan Nov 18, 2013
    Thanks for the info! On the motors I have been dealing with the only wiring options on the switch plate are if you want to convert the motor to 115v from 220v. Otherwise the motor is 115v only or 220v only. Obviously there are others out there where the start windings can be switched. I'll definitely remember the other possibility, thanks.
LG FFH-M200
If you hear the CD spin but nothing happens, most likely the lens on the laser pickup is dirty. You can take a q-tip dipped in alcohol (not dripping), rub the lens and gently blow it off with canned air. This will remove dust from under the lens as well. I don't recommend "lens cleaner CD's" that you can purchase as they sometimes rip of the lens.
If the CD does not spin up to the proper speed, it is the motor that spins the disk. This can be temporarily fixed by disconnecting the motor wires and using a 9 volt battery to spin the motor in each direction. The trick is to revers the direction while it is still turning in the opposite direction. This will hopefully burn off the carbon and debris in the motor contacts.
Apr 12, 2014 | Audio Players & Recorders
WIRING A COMPATIBLE POOL PUMP[MARATHON 1 H.P.230V
check for 230v not 110 (on line to ground). SO checking L1 and L2 should show 230 v if not you have a fault in the timer or the breaker is toast. depending on the timer you can clean the points
Jun 30, 2017 | Pool & Spa
Problem with Kettler Marathon ST, error 01 and not starting
adjust the speed sensor, see the diagram attached, clean, and tight the wires connector very well.
2) Test the input voltage motor, if there are the motor need repair.
3) Tes the output voltage board, for input voltage motor, if there are NOT the board is faulty.l
After you did, RUN the software calibration for diagnose, troubleshooting,and fix it.
sincerely. GOD bless you
May 05, 2012 | Kettler Exercise & Fitness
Fan is spinning opposite way
there should be like a switch to change direction of fan , if not then you need to change the wire connection , try that , AJ
Aug 13, 2009 | Ellington ROC52ALUM3LKRCR2 Rocket Ceiling...
Queen marathon 20 years old does not pump the
If the motor is running then the water pump or the clutch to it has failed. If the motor is not running, the motor has failed. Both fixes are probably too expensive for a 20 year old machine. Unless you are very handy and resourceful it may be time for a new machine.
Jul 11, 2009 | Washing Machines
Hayward 2HP Pool Pump Motor A O Smith Electric Pool Motor  for 56J Frame Logo
169 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
