Question about FAN-TASTIC VENT Fantastic 6000rbta 12 volt ceiling fan 3 speed thermostat dome
Trying to program the remote - all 7 LEDs supposed to flash and they don't
Have tried the re-programming - removed the batteries and the fuse. pressed auto and manual arrows simultaneously. Auto and Manual begin flashing immediately but the seven LEDs will not flash
4x4 diesel. Why can't doors be unlocked or locked?
their is a way to do it but recheck battery first sometimes the relearn process doesnt work or the fob itself is dead also if auto /remote start will need dealer to flash fob ---- 2002 santa fe and followed programming instructions and eventually was able to program the new remote. But, I did not realize I had to program my existing remote at the same time. Since, I have retried programming both remotes many times with no success--the new one works, but the old one won't. The instructions were: 1) Locate switch under dash, behind fuse box; 2) Turn ignition switch on, but don't start engine; 3) Wait 5 seconds, set memory switch to SET position; 4) Press remote LOCK button; press second remote transmitter LOCK button; 5) Set memory switch to OFF; 6) Switch ignition OFF. 7) Confirm programming by locking and unlocking vehicle.
Remote Key Programming Hyundai Forums Hyundai Forum
Sep 23, 2015 | 2003 Hyundai Santa Fe
NED 8700 smart button location
a marantec ned8700 has no smart button you have to open the remote n remove the battery then connect the programming 3-prong cable to the terminal on the side of the remote (under the rubber cover) the with a flat screwdriver short out 2 of the prongs one must be the center prong. press and hold the button on the remote that is active, in 2 seconds code will change. elease the button after the light illiminates continuously then remove the programming cable/prongs and replace battery n cover then press n release p button on machine till only 7 lights up take remote hold it 3'' away from button and press button on remote to program for 10 secs release then push p button on machine once, 8 will light up and your set to go
Nov 04, 2012 | Genie Company Home Security
Hi, my old remote key pad used to lock itself so if I bumped it in my pocket it wouldnt start. I bought a new 2 way recently but the key pad stays unlocked. How do I get it lock?
Press and hold the "f" for 8 seconds to access the remote programming features. The remote will emit one long beep and the LEDs will illuminate. Press the unlock button to access the remote programming features. Two transmit LEDs will flashes and two beeps indicate the remote programming features are accessed. Press the lock button on the remote( LED on indicates auto locking on, LED off indicates auto locking off). Press and release "f" button to exit programming.
Apr 12, 2011 | 872 Responder LE keyless entry security...
I need to program the key less entry
IMPORTANT: Before entering programming mode, have in possession all of the remotes you
will be useing on the vehicle. Once you program the remote. all previous remotes that were
programmed will be erased from memory. The other remotes will not be functional until you
program the them again.
1. Remove the key from the ignition.
2. Close all doors.
3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or
owner's manual to properly locate the "MALL PGM" fuse.
4. Insert the key into the ignition, and turn to the ACC position.
5. Turn the key to OFF and then back to ACC within 1 second.
6. Open and close any vehicle door. A chime will be heard when the system enters into
programming mode.
7. Press and hold the remote LOCK and UNLOCK buttons simultaneously for 14 seconds.
IMPORTANT: After 7 seconds, a chime may be heard confirming successful
synchronization. It is necessary to wait approximately 14 seconds for a second chime
that will confirm successful programming.
8. Repeat step 7 now for each additional remotes to be programmed including any existing
remotes.
9. Remove key from ignition.
10. Install the "MALL PGM" fuse back into the fuse panel and test remote(s).
May 10, 2010 | 1998 Pontiac Grand Prix
How do i program the remote
IMPORTANT: Before entering programming mode, have in possession all of the remotes you will be useing on the vehicle. Once you program the remote. all previous remotes that were programmed will be erased from memory. The other remotes will not be functional until you program the them again.
2. Close all doors.
3. Remove the "MALL PGM" fuse from the fuse panel. Use the legend on the fuse panel or owner's manual to properly locate the "MALL PGM" fuse.
6. Open and close any vehicle door. A chime will be heard when the system enters into programming mode.
synchronization. It is necessary to wait approximately 14 seconds for a second chime that will confirm successful programming.
8. Repeat step 7 now for each additional remotes to be programmed including any existing remotes.
Thank you for using fixya and good luck
Apr 27, 2010 | 2000 Pontiac Grand Prix
I have just changed the batteries in my key fob for my P reg. ford fiesta but it won't open the doors
Programming
When
Key batteries completely discharged. Key batteries not replaced within 15 seconds. Key added or replaced. System malfunction.
How
Obtain all keys fitted with remote control. Turn ignition switch to position I. Wait approximately 10 seconds. Ensure clock LED illuminates.
NOTE: LED illuminates for approximately 5 seconds.
Switch ignition OFF and remove key, while LED illuminated. Programming mode activated for approximately 20 seconds (LED illuminated). Proceed as follows: Point key at receiver (located near interior lamp). Press and hold unlock button Fig. 1 [1]. After approximately 1 second key LED will flash once [3]. Press lock button 3-5 times Fig. 1 [2]. Release unlock button Fig. 1 [1]. Continue to point key at receiver until LEDs in clock and key have flashed 5 times. Repeat above procedure within 20 seconds to program remaining keys. To exit programming mode and extinguish clock LED: Switch ignition ON and OFF. Wait approximately 20 seconds
Jan 16, 2010 | 1995 Ford Escort
I have lost manufacturers manual on my BMW 325ci 2001 model. i only require pages relating to the programing of automatic garage door thank you
NOTE: Some vehicles may require the ignition to be turned on or to the second (or"accessory") position for programming and/or operation of HomeLink. It is also recommended that a new battery be replaced in the hand held transmitter of the device being programmed to HomeLink for quicker training and accurate transmission of the radio frequency. Please use a ladder and do not stand on your vehicle during the programming steps for a rolling code opener.
Rolling Code Programming:
1. Press and hold the two outer HomeLink buttons until the indicator light begins to flash (after 20 seconds). Do not hold for longer than 30 seconds. Do not repeat this step to program additional HomeLink buttons.
2. Place the hand-held remote 1-3 inches from the HomeLink button you want to program.
3. Simultaneously, press and hold both the HomeLink and hand-held remote buttons. Do not release either button until step 4 has been completed. (If you reside in Canada, refer to the "NOTE" below.)
4. When the indicator light changes from a slow blink to a rapid flash, release both buttons.
5. At the garage door opener receiver (motorhead unit) in the garage, locate the"learn" or "smart" button (usually near where the hanging antenna wire is attached).
6. Press and release this "learn" or "smart" button. (The name of these buttons vary by manufacturer.) There are 30 seconds in which to initiate step 7.
7. Firmly press, hold for two seconds, and release the programmed HomeLink button. Do this procedure again and, depending on the make of your garage door opener, do this procedure a third time to complete the procedure.
The garage should now activate when the programmed HomeLink button is firmly pressed and released. If not, give us a call or refer to the "Troubleshooting Tips" noted below. NOTE: If you reside in Canada, replace step three with the following: Press and hold the desired HomeLink button and "cycle" the hand-held remote. To cycle: Press and release the hand-held remote button every two seconds until the indicator light changes from a slow blink to a rapid flash(step four).
Troubleshooting Tips:
** Check the frequency of the garage door opener's hand-held remote (usually found on the back). HomeLink is compatible with radio-frequency devices operating between 288-399 Mhz.
** Put a brand new, store bought battery in the hand held remote. During the programming process (step three above) the battery's energy tends to drain (more so with an older battery). A new battery will increase the speed and accuracy in which the hand-held remote sends its signal to HomeLink.
** Retrain HomeLink holding the hand-held remote at different lengths and angles from the HomeLink button you are trying to program (during programming step three). Try 4-6 inches away at a different angle.
** Confirm that the HomeLink button you are trying to program is in the "programming mode". Press and hold the desired button. The indicator light will be a slow blink when HomeLink is in the "programming" mode and can be programmed at any time.
Verifying HomeLink has picked up a rolling code signal:
** Press and hold the programmed HomeLink button. If the indicator light blinks rapidly for two seconds and turns solid, HomeLink has successfully picked up the rolling code signal. If necessary, proceed with steps 5-7 noted above to complete the rolling code programming.
Sep 09, 2009 | 2001 BMW 325
Trying to program my At&t Uverse remote to my
Sherwood Receiver/Amplifier 5027 Sherwood Receiver/Amplifier 5027
always press the mode key of the device they want to control before pressing any other key
Power on the device
  1. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  2. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  3. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
    1. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    2. The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
    1. Point the remote control at the programmed device and press the Power key once.
    2. The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
    1. Repeat steps 1 through 7 to program other devices if needed.
    2. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
    Sep 05, 2009 | Sherwood RX-4109
    Where is the bcm program fuse on a 2005 pontiac montana sv6
    The BCM program fuse on a 2005 Montanna SV6 is called something different in the manual. It's called a “Keyless Entry Module” fuse and it is fuse #7. The fuse panel is located on the passenger side on the side of the dash. There is a cover with an indent hole in it to pull the fuse cover off. It's really hard to pull it off and it almost seems like your going to break it when your trying to get if off. Keep pulling, it will come off! On the fuse cover, fuse #7 is labeled " RFA MDLS" which is again different than what is in the manual. I followed the procedure to reprogram my "Key Fob" and within 45secs, I had reprogrammed my key FOB! I was so excited, because, I have been trying locate the BCM fuse for 4 weeks. I think GMC does not want us to know it’s location or name, so you would have to go into a dealership to get your Key Fobs reprogrammed costing about a $100 for a minute of work.
    1. Keep the windows open as a safety measure, then,
    2. Remove the ignition key from the ignition lock cylinder.
    3. Remove the “RFA MDLS” (fuse #7 ,BCM PRGRM fuse, Keyless Entry fuse) from the fuse panel.
    4. Close all of the doors.
    5. Close the liftgate.
    6. Turn the ignition lock cylinder to ACC.
    7. Turn the ignition lock cylinder to OFF, and then back to ACC within 1 second.
    8. Open and close any vehicle door. A chime will be heard when the system enters the BCM programming/diagnostic mode.
    9. Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
    10. Important
    After 7 seconds, a chime may be heard confirming successful programming.
    11. Repeat the previous step on each additional transmitter to be programmed.
    12. Remove the ignition key from the ignition lock cylinder
    13. Install the “RFA MDLS” fuse ( fuse #7 ,BCM PRGRM fuse, Keyless Entry fuse) back into the fuse panel.
    14. Press on the key fob functions (EG. Lock, Unlock) to verify correct operation.
    Mar 17, 2009 | 2006 Pontiac Montana SV6
    1997 venture keyless remote programming
    SYSTEM OPERATION
    System warning lamp located on top of the instrument panel
    Press UNLOCK button once , turns on interior lamps and deactivates alarm (if fitted)
    Press UNLOCK button twice w/in 5 seconds unlocks all doors, turns on interior lamp and deactivates alarm (if fitted)
    To activate alarm system (if fitted):
    Switch ignition OFF
    Open driver's door
    Press Lock button on remote
    Close Driver door
    warning lamp will flash when system is activated
    Press remote power sliding door button will open sliding door (if fitted) only if unlocked first
    Pressing remote panic button:
    *Sounds horn intermittently
    *Flashes exterior lamps
    *Turns on interior lamps
    **Pressing panic for the second time OR switching ignition ON deactivates alarm.
    PROGRAMMING
    Remobe key from ignition switch
    Remove the "BCM PRGRM" fuse, from the fuse box
    Close all doors
    Turn ignition switch to the ACC position
    With in 1 SECOND , turn the ignition switch to OFF then back to 'ACC'
    (really, with in one second)
    Open and close the driver's door. A chime will sound, indicating programming mode activated
    Press and HOLD LOCK and UNLOCK SIMULTANEOUSLY untill a chime sounds 2 times ( about 15 seconds)
    Repeat this exact procedure for all remotes to be programmed
    Refit 'BCM PRGRM' fuse.
    4 REMOTES MAXIMUM CAN BE PROGRAMMED
    Aug 24, 2008 | 2000 Chevrolet Venture
    FAN-TASTIC VENT Fantastic 6000rbta 12 volt ceiling fan 3 speed thermostat dome Logo
    Top FAN-TASTIC VENT Dryers Experts
    Are you a FAN-TASTIC VENT Dryer Expert? Answer questions, earn points and help others
