Zinn gpm ges gesch - Computers & Internet
I'm looking for the owner's manual to a Fuji 2016 Nevada 1.5 mountain bike 29er
contact a Fuji dealer or their website. BTW owners manuals are very generic and the same manual is used for all models of bikes that a manufacturer produces. If you want specific information on how to maintain and fix your bike a good bike repair manual will do you much better, like the Park Tool Manual, Leonard Zinn's repair manuals, the Barnett's manuals and many others.
Apr 12, 2016 | Fuji Cycling
2001grand prix will not shift to any ges t
I need more information. When you say "...will not shift to any ges..." I assume you mean gears. More importantly, are you saying the gear select lever (shifter) is frozen in place and will not move? or are you saying you can move the shifter, but once you have done so the transmission will not engage and move the car? Also is this a stick shift or an automatic?
May 28, 2014 | Cars & Trucks
My rinnai heater keeps my water running hot and cold, hot and cold and I can't have a decent shower! How do I stop it from doing that?
if it has been constant from instalation it might be that ur shower head is rated too low to get enogh gpm ( gallons per minute) it will tell u most of the time around the shower head where it threads onto the spot of the wall what the gpm is. alot of the energy saver heads are restricting tehgpm to 1.5 or .5 gpms to conserve water well the water heater will only operate correctally around .5 gpm depending on model so if u are not pulling enough water u will not turn the water heater on to get ur hot water all the time so go to lowes ( or locally trusted hardware) and get a new shower head make shure u look for the gpm on teh head and check in ur owners manual to see what gpm ur water heater kicks on
P.S. if ur shower head is rated at higher gpm say 1.5 and it is corroded or pluged up say with lime it is going to restrict it causing a lower gpm
Jan 13, 2011 | Bosch 2400ES LP AquaStar 6.4 GPM Indoor...
1994 honda accord failed its emisions test.
i would say change the O2 sensors and a new cat ,these readings are well over the top ,could have a exhaust blow on exhaust as well which will throw out the O2 readings
Nov 07, 2009 | Honda Insight Cars & Trucks
I have an EC-100 S Ibico Calculator. How do I use the GPM button to calculate margin?
Kelly,
For GPM on ibico EC-100 S:
Enter Price
Hit Minus Key
Enter Cost
Hit GPM Key to get GPM
Oct 07, 2009 | Ibico EC-100S Calculator
Huffy® 26'' Commuter Bike where can I find assembly instructions ?
There should be general books, like howard zinn's, on general bike maintenance available at your local bike shop, but not specifics on bicycle assembly. Simply take it to the shop and they will assemble it for about what they charge for a tune-up.
Sep 11, 2009 | Huffy Cycling
Owners manual for a shimano bicycle
Not sure you will find an owners manual but I highly recommend the book Zinn and the art of bicycle repair. Zinn is the author. He covers every fix imaginable for new and older/vintage bikes. He probably has several versions of the book out.
Jan 13, 2009 | Cycling
Computers & Internet Logo
David Payne
David Payne
