Question about Beckett CB201UL - 115V Condensate Removal Pump 19 Lift
Pump will not shut off
After my house is warmed the pump does not shut off I was told it only should come on after condensation fills resivore to point pump out and shut down any ideas ?
4.7 CONDENSATION ON OIL FILL CAP
You have water getting into the sump. Have a compression test done to check the head gasket and cracked head.. The water may be coming in from pin holes (Corrosion ) behind the water pump impellor in the aluminium housing
Dec 24, 2013 | 2004 Dodge Ram 1500
Tip
Gas Boiler Condensing Best Features
Condensing boilers are the most efficient way to heat that there is today. The BTU’s that they wring out of the fuel put into them is the best of anything available today. Not only do they burn their fuel very well, they also have technologies built into them to help give then the highest efficiency possible on any given day.
Condensing gas boilers have been on the market for about twenty years now. The early boilers were noisy and very heavy. Today’s condensing boilers are not even remotely the same as their predecessors. There have been many improvements that make these boilers lighter, safer, and more reliable than ever.
Many of today’s condensing gas boilers are controlled by a computerized control that gives many options and features to customize your boiler to the type of system that it is being installed in. Not only does the control monitor the boiler, but it can be setup to control the whole heating system as well. This gives the added benefit of fewer controls and the saving of space. Circulator pumps, mixing controls, and injection pumps can all be controlled by the boiler control.
These technologies are things like sensors to make sure that they are running at the highest combustion efficiency possible or they will shut down. Outdoor reset controls will vary the water temperatures to make sure that the water temperature is only being heated as hot as is needed to make your house warm at any given outdoor temperature.
Sensors also monitor the supply and return water temperatures constantly to shut down the boiler if the boiler senses any unsafe conditions.
These boilers are so good that even if you fire the boiler before filling it with water, the boiler will shut off before it is damaged.
When looking at the boilers on the market today take into consideration all of the benefits of that the newer high efficiency boiler have to offer. High efficiency is really great, but there is so much more to them. The ease of installation because of the light weight of new condensing technology, the versatility of the controls that are incorporated into these boilers, and the outdoor reset technology that will save you fuel and make you much more comfortable.
http://www.fixya.com/support/r3706297-gas_condensing_boiler_high_efficiency
http://www.fixya.com/support/r3583943-condensing_gas_boilers__the_best_radiant
http://www.fixya.com/support/r3597748-the_extra_benefit_of_a_modulating_boiler
on Dec 24, 2009 | Heating & Cooling
The condensation tank is filling and causing the unit to shut down every two hours. The internal pump that sprays water (from the collection tank to the exhaust vent) is apparently not working. Will this...
Shut it down until you get the drain working again. That spray is what helps save you a few buck on your Cooling bill. Let that excess water get in your house then maybe kiss your pocket book goodbye
Sep 10, 2013 | Amcor PLM-14000E Portable Air Conditioner
We installe da T8011R Programmable Heat Pump Thermostat approximately 2 years ago and two weeks ago, the a/c unit began turning itself completely off (blank screen and all) several times a day and night...
If the screen is blanking out that means that the 24 volt power to the thermostat is being disrupted.
The most likely cause is a safety switch on the secondary condensate drain line. This means that the primary drain line is almost totally clogged and that the condensate backs up enough to trip the condensate overflow switch. When it shut the system down (blank thermostat) this allows time enough for the condensate to slowly drain out and the safety switch resets itself. Clean out the primary condensate drain line (hook a shop vacuum to the line where it terminates outside and sucks the gunk out of it), this should take care of the problem. If it does not then you may have to get an a/c technician to professionally blow the line out from the air handler and possibly clean the condensate tray out in the air handler.
Hope this helps.
One note: If the safety switch was properly installed then the system would shut off and never come back on until the drainage was corrected. Yours is obviously not installed properly.
Sep 10, 2011 | Honeywell Programmable Thermostat Heater
Cars over heating leeking coolent for the bottom and not sucking in form the resivor and not leaking form hoses
Change the thermostat. Follow upper radiator hose to where it meets the thermostat housing on the engine. Remove the 2 or 3 bolts that hold on the housing, then replace the thermostat and seal and put housing back on. With cap still off, vehicle running and warm, then fill up the coolant system. Make sure there is not air pockets by burping the hose when adding the fluid.
Dec 31, 2010 | 1999 Plymouth Breeze
Intruder 1500, 1999, why can't I find the fuel
You dont have any fuel shut off valve because you have fuel injection which uses an electric fuel pump inside the gas tank all you need to do is buy a fuel additive called stabil and add the appropriate amount to the gas and you will have no problem. Make sure you fill your tank all the way up. because if you leave it like half way the upper half gets condensation and moisture . so just fill it up add stabil take out your battery and bring it in the house so it stays warm and dry and you will be good to go in the spring.
Nov 02, 2009 | 2000 Suzuki VL 1500 Intruder LC
Little Giant Condensate pump runs for 1 sec when res not full
Is there a check valve in the pumps discharge fitting? If there is it may be stuck open or broken allowing some of the water to return to the reservoir once the pump shuts off which then may lead to the brief cycle between full cycles.
If there is not one, install one to keep any water from backing back into the reservoir and that should stop the short runs.
Aug 06, 2009 | Plumbing
I have the washer on cold water, but it runs warm, stops, trickles, then comes out warm again, stops, trickles, then warm again ect.On the rinse cycle it will only trickle out.
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Mar 03, 2009 | Washing Machines
How to change out thermostat in 1991 buck centry 3300
your thermostate is probably on the block sideways in whitch case you need to remove the air filter outr of your way and loosen the clamp on the thermostate housing. from there take out the 3 bolts holding the thermostat housing in place and remove it. Caution water/antifreeze will come out. take the thermostate out watching where the gasket has been placed and install the new one after cleaning the suface of the old gasket. sometimes it is good to use indian head gasket sealer. there will be 2 bolts on top and 1 bolt on the bottom under the housing. install the new thermostate tightn the hose replace your filter and fill the over flow resivor only to the point on COLD MAX. take the cap off the radiator start the car wait for the thermostate to open and fill the raditor the rest the way up. if it starts to boil over just shut the car off and let it cool than add more water *** needed...
Aug 01, 2008 | 1991 Buick Century
Ruud UBHC17J11NFA: Condensate pan filling up - condensate pump works fine
blow out the drain line from the coil to the pump the clog is there causing the pan to fill up and trip off
Apr 28, 2008 | Ruud UBHC Air Conditioner
Beckett CB201UL - 115V Condensate Removal Pump 19 Lift Logo
Top Beckett Plumbing Experts
Dave
bobalix
Gil Shultz
Are you a Beckett Plumbing Expert? Answer questions, earn points and help others
