Question about Tivo Televison & Video
Netzero tivo setting up wireless n network tivo adapter with premiere tivo
  • 173 Answers
SOURCE: wireless network
Do you remember your wireless network name and the wireless security password for your router, check if you are able view the wireless network, try connecting to it..if it asks for passworg type in your password and check if nor revert back..
Posted on Jul 18, 2008
SOURCE: My wireless network gets dropped
HI! that is correct.. your device wont connect bcoz you change the wep, ssid name etc on the router.. if the security settings is change from the router and your wireless devices have the old settings it wont work and it will not connect.. you need to enter the new wep, ssid name etc to the wireless devices in order to connect to the wireless network..
Posted on Aug 09, 2009
jeevan.m
  • 392 Answers
SOURCE: Can't connect through my wireless G network adapter.
Give the default gateway address of your laptop computer in the desktop computer. this will solve your issue.
Posted on Sep 02, 2009
  • 35 Answers
SOURCE: np wireless connection..
hey
which laptop is it or if it is desktop check under device manager if we have the ethernet controller available under other devices
check their properties and go to pcidatabase.com and find out teh manufacturer for the device and download the drivers
Posted on Sep 18, 2009
  • 825 Answers
SOURCE: When trying to connect to
the usb wifi adapter is supposed to be plugged in only in the computer and not in the blu ray players...
Posted on Aug 22, 2010
DriverAg0100 Driver Download
You don't need a driver for the Tivo AG0100... you plug it into one of the USB ports of a TiVo DVR and configure it from the Settings & Messages -> Settings -> Network -> Change network settings menu in the TiVo DVR.
Jun 10, 2013 | Tivo AG0100 Wireless G USB Network Adapter
Tip
Do you have a Tivo Premier and are you experiencing wireless communication...
Recenty, I discovered that devices were dropping off of my wireless network (Netgear N300 wireless N with DSL modem). After trial and error, the solution to the wireless communication problems was to create a wireless N bridge using the Tivo Wireless N adapters.
To use this feature, you will need two Tivo wireless N adapters. One wireless N adapter should be set to bridge and plugged into an available ethernet port into your router. The second adapter should be set to client and plugged into the ethernet port in the back of the Tivo Premier. Once the power has been applied to both wireless adapters and the Wireless adapter (connected to the router) has connected to an available address on your router, press and hold the button (on top of each adapter) to establish a secure wireless connection between both adapters.
Once each adapter has established communication, you will have a separate 5Ghz Wi Fi signal (as well as a channel )dedicated to you Tivo devices throughout the house. Each Tivo Premier added to the house should have the wireless N adapter and connected using the secure connection to the wireless bridge by pressing the button on each adapter (the one on the router as well as the one on the Tivo to install).
If sucessfully installed, you should be able to connect to all Tivos on the network for management as well as streaming. If communication between the Tivos isn't successful, you will have to restart each Tivo and establish a new connection to the Tivo service.
Another suggestion when using the wireless N adapters is to setup a static IP address on each Tivo that is higher than the IP address assigned to the wireless adapter. Each Tivo utilized two IP addresses for each device (one for the adapter and one for the Tivo). You may have to check the router administration screen to determine the IP addresses used for the wireless adapters before establishing a static IP address for the Tivos. If you assign static IP addresses to each Tivo, you will have to restart each Tivo and reconnect them to the Tivo service to establish proper network mapping.
With this wireless network configuration, you will ensure that your Tivos are connected to the service using high speed, dedicated wireless N communication for streaming purposes between the services offered while not impacting other computers, servers, video game machines, and tablets that are connected into your house.
Since the Roamio uses a built in wireless adapter, you may not have success in adding a Roamio to the wireless bridge created on your router unless you disable the built in wireless adapter and purchase the external wireless N model from Tivo.
Instructions on setting up wireless bridge can be found at this location:
http://support.tivo.com/app/answers/detail/a_id/1590/kw/wireless%20n%20adapter
on Oct 02, 2013 | Tivo Premiere 4
Tip
I cannot locate the disc for my TIVO, and am trying to get the TIVO wireless...
Right-click the "Network" icon in the Windows Notification Area at the bottom right of your desktop, then click the "Open Network and Sharing Center"option from the menu.Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option.Click the "Configure" button, then click the "Advanced" tab.Click the "Channel 802.11n/b/g" option from the menu, then type a new value between 1 and 11. Click the "OK" button to save the changes and close the dialog box. Update Wireless Adapter Driver Right-click the "Network" icon in the Windows Notification Area, then click the"Open Network and Sharing Center" option from the menu. Click the "Change Adapter Settings" link and right-click your "Wireless Network Connection" icon, then click the "Properties" option. Click the "Configure" button, then click the "Driver" tab.Click the "Update Driver" button, then click the "Search automatically for updated driver software" option. Windows automatically searches for and installs the latest driver for your wireless adapter.< Click the "OK" button on both dialog boxes to save the changes and close the window.Update Router's Firmware <li>Click the "Start" button, then click the "Computer" l Click the "Network" heading from the left pane, then double-click the"Internet Gateway Device" icon under the Other Devices section. Your default browser launches to the login page of the wireless router. Type the username and password, then click the "OK" button to log in. Click the "System" icon and then click the "Update" option. Click the "Yes"button when the wireless router configuration tool asks if you wish to search for the latest firmware on the Internet.out of the router's configuration utility boost-wireless-adapter-signals.
on Dec 31, 2010 | Tivo Wireless-G USB Network Adapter
How to insert dvr in a network
Using a TiVo as an example. If you have an ethernet cable you can simply plug that in, or for wireless you typically have to buy a small adapter. Plug that into the TiVo and go into the settings menu, phone and network. Select your wireless network SSID (name) and enter your password if you have one. Set it up for DHCP or static, your choice. DHCP is a no brainer. Now you go to TiVos site on your PC and download their software and you should be able to connect to the TiVo and watch the shows on your PC.
Apr 17, 2012 | Computers & Internet
I want to get the TIVO AG0100 wireless adapter. I do not have wifi in my house so will it still work? I'm not planning on getting wireless for my computer.
Dear,
Since it's an adapter and not a router, it will not work if you don't have a previously installed wireless network.
You might buy a wireless router and connect it to your computer and use Tivo at the same time.
Jul 22, 2011 | Tivo AG0100 Wireless G USB Network Adapter
We have lost the original disc that came with the TIVO and I need to get the Tivo wireless network adaptor set up on our wireless network. How can I do that without the disc, is thee anyway around that ?
The disk us usually not necessary. If you are using a series 2 TiVo you just plug this in to the back of the TiVo and it will recognize it. In the TiVo menu find Network Settings. If you select change network settings it will ask you to select your wireless router and ask for the password to your router if you are using one.
I have a macbook and am trying to set up a new tivo premiere xl with a wireless n adapter. i am stuck at the phase were i have to put in 192.168.10.1 to be able to continue my set up. at 192.168.10.1 i...
I don't think your Macbook is required in this situation, if I understand correctly the wireless N adapter plugs into the tivo correct? If so then your entering the data via some sort of input device (keyboard, remote, etc.) into the settings for your tivo. Try powering your router off waiting 30 secs and then power it back on, then try entering the data again. It could also be that your router doesn't use the 192.168.10.1 numbering scheme, some routers like apple's use a 10.xx.xx.x system and others use 192.168.1.xxx. I'm guessing that the tivo setup is asking for your routers IP address so it can assign the wireless N adapter an IP address of its own via DHCP. If this is the case try looking in your router's user manual to see what the router's IP address is set to by default when you first install it. Hope this helps, I could help further if I had some more information about the situation. If this does solve the problem, don't forget to vote, rate, comment, etc. Thank you.
Jun 02, 2010 | Apple MacBook Mac Notebook
Adapter does not detect wireless network
Check to see if is compatible with tivo.
Some units are not compatible with tivos...
May 30, 2010 | D-Link Air DWL-122 802.11b Wireless...
Televison & Video Logo
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
