Question about aFe 2001 Pontiac Grand Am - 2.4L 4-cyl. engine - Air Filters
Need a diagram for spark plug wires for 2000 Pontiac Grand Am 2/4KL
Diagram for spark plugs
  • 8,220 Answers
The longest is one all the way to the left. 2 next longest 3 next shortest. 4 shortest. This guy made a video of it post a comment to his video and ask him. he prob knows. that is what I would do.https://www.youtube.com/watch?v=40NQtloSXsc
Posted on Nov 16, 2013
Xl15 wiring schematics
Request a wiring diagram directly from Alpine Air.
May 12, 2017 | Air Air Purifiers
Bought a 2000 grand am, need to change spark plugs. any help appreciated
Frankie, See how to change the plugs on your Grand AM. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Spark Plug Wires Remove Replace How to Pontiac Grand Am
remove and replace spark plugs
How to change spark plugs on 2000 Grand Am ShopYourWay
List Spark Plug 2000 Pontiac Grand Am Reilly Auto Parts
Jul 11, 2016 | Spectre 2000 Pontiac Grand Am - 2.4L...
Need a wiring diagram for Oreck XL air purifier Air8SD
I would look at the board using a high powered magnifying glass to see if there was any signs of broken stubs of wires sticking out of any solder joints. Also look for solder joints that have no other possible routes, (dead ends) that do not have any other connections running from them. Like a resistor that has a copper path on one end and nothing running from the other end. Or it could be a ground wire if no other spot is found.
Aug 04, 2014 | Oreck Air Purifiers
Why does my car just turn over but wont start
A suggestion would be to check your fuel filter to make sure it is not stopped up. Your fuse to the fuel pump may also need to be checked. Chevys are notorius for bad fuel pumps.
Jun 03, 2014 | aFe 2001 Chevy Cavalier - 2.4L 4-cyl....
Won't start
Hi James,
Did truck die on you while driving or just not start one day? It is very likely you need a new fuel pump. AIRTEX Part # E2363M, but double check. Checking bad pump requires OBD II scanner to read codes:
https://www.youtube.com/watch?v=nu2YJQ1xOss
Changing fuel pump is not hard, but takes a set of skills, time & care is also required. 2.3L is fuel injected which means it is in your fuel tank.
(If you had a carburetor the pump would be at front of engine & easier)
You will need a trusty mechanic or some good friends..New pump is about $135 from Rockauto slightly more from O'Reilly etc.. Dealer will double that price, local mechanic will charge $150-180 plus hourly labor.
Something else in addition to air filter, that you can do yourself is change fuel filter & plugs. Get better mileage to help pay for new pump. Fuel filter is about $30 for good one. The fuel filters are located in nearly same location on all Rangers regardless of engine & year.
https://www.youtube.com/watch?v=5taAFsAbx0U
Changing spark plugs
https://www.youtube.com/watch?v=-UujrhSmPho
If it is firing, but doesn't quite want to go also be sure you have spark.
Remove plug wire number one and carefully put a nail into spark plug cap, rest it on the exhaust manifold while you watch have someone turn the engine over for a brief moment to be sure you see spark. DO NOT TOUCH while turning over or you can get a nasty shock.
Check fuses as well. PEACE
May 26, 2014 | Spectre 2004 Ford Ranger - 2.3L 4-cyl....
Where can I find wiring diagram for Ecoquest air purifier. Replaced UV lamp and disconnected wires and cannot remember how to place them.
Try checking the contacts to the ozone plate. Or a wire may be loose--check the contacts and sometimes they need to be cleaned with alcohol.
Apr 19, 2012 | Ecoquest Fresh Air Air Purifier
Spark inside the filter
It's probably arcing due to a buildup of oxidized particles from the air and the high voltage field wires. Spraying electrical contact cleaner in the vicinity of the spark/arc may clean it -- make sure the unit is not plugged in when you do this and that you give it plenty of time to dry before plugging it back in (couple of hours). If cleaing doesn't help, there's not much you can do -- the wire will eventually burn through and break. Then it's back to Oreck or to the landfill.
Apr 21, 2009 | Oreck (AIRCOM1WOI) Air Purifier
Filter not clicking or emitting clean air smell and dust is flowing like filter is not energized
MAKE SURE THAT YOUR CELL(S) ARE CLEAN ... CLOSELY INSPECT TO SEE THAT THERE ARE NO BROKEN IONIZING WIRES (THE SMAAL STAINLESS-STEEL WIRES THAT ARE BETWEEN THE COLLECTOR PLATES). MAKE SURE POWER GOING INTO UNIT TO IS "OFF"!!! ... NOT JUST THE SWITCH ON THE UNIT. THEN TRY THE FOLLOWING: THIS AIR-CLEANER THAS A AIR-FLOW SENSOR THAT SOMETIMES GETS CLOGGED ... IT IS INSIDE THE TOP CONTROL PANEL. THERE SHOULD BE A DIAGRAM UNDER THE CONTROL BOX COVER PLATE TO ASSIST YOU LOCATING THAT SENSOR. MAKE SURE IT IS CLEAN. THE HIGH-VOLTAGE TRANSFORMER BEING BAD USEUALLY WILL SMELL LIKE BURNT WIRING. AND WILL LOOK BURNT. MAKE SURE YOU SEE NO LOSE WIRES ... SOME TIMES THE SPARK-PLUG LOOKING WIRE GOING TO THE CELL(S) CAN BURN OFF ITS CONNECTOR. YOU CAN CHECK THE DOOR SAFETY SWITCH TO MAKE SURE IT IS MAKING CONTACT WHEN HANDLE IS PROPERLY CLOSED. GOOD LUCK ... HOPE YOU HERE THAT ZAPPING SOON ... BY THE WAY ... IF YOU GET A POWER LIT ON ... GIVE THE RETURN-AIR DUCT A SLIGHT BANG ... IF IT IS WORHING IT SHOULD SNAP CRACKLE AND POP FOR A FEW SECONDS. MAKE SURE YOU SEE NOTHING (HAIR?) LYING ACROSS THE PLATES OR IOMIZING WIRES ON EACH CELL IF YOURS HAS TWO. ELECTRIC AIR CLEANERS ARE ONLY GOOD WHEN THEY ARE KEPT CLEAN ... PET HAIR IS A CONSTANT MAITENCE PROBLEM AND CELLS SHOULD BE LEANED EVERY TWO WEEKS. FOR BEST PERFOMANCE. Joe_Rex 40+ years Hvac Contractor (retired)
Apr 29, 2007 | Honeywell Enviracaire Elite F300E-1019 Air...
aFe 2001 Pontiac Grand Am - 2.4L 4-cyl. engine - Air Filters Logo
74 people viewed this question
Top aFe Air Purifiers Experts
Dan Webster
Dan Webster
Pcm2048
Are you an aFe Air Purifier Expert? Answer questions, earn points and help others
