Question about Kenwood KDC-MP208 Car CD/ MP3 Player
Which color wire is the remote wire - Kenwood KDC-MP208 Car CD/ MP3 Player
I need to know what is the color of the remote wire on a 07 doge ram slt quad cab 4x2
The amp remote is actually run by the computer bus line. This is a twisted pair of wires that allow computers to talk back and forth.. therefore it does not have a remote wire. Best bet is to run amp on a switch or a keyed power wire for remote turn on. Also if u plan on changing stereo u will need to buy a interface kit or truck may not even run
Aug 23, 2014 | 2007 Dodge Ram 1500 Quad Cab Sport
I need the color coded wiring diagram for a linear UVD9010
Red wire= 12V switched
Yellow= 12V constant (memory)
Black=ground
Blue=Amp remote wire
Pink=emergency brake safety
Speaker wires are paired by color with black stripe being negative
Jan 12, 2012 | Phase Linear UDV9010 Car DVD Player
What color is the remote wire on a sony xplod car stereo?
the amplifier remote wire is blue/white, the power antenna remote wire is blue, the power antenna remote wire turns off when leaving tuner mode.
Mar 18, 2011 | Sony Car Audio & Video
Color codes for my jvc arsenal kd-ar560 wire harness
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Apr 24, 2009 | JVC Arsenal KD-AR560 CD Player
Remote wire color?
the remote wire will be a solid blue this is always the color no matter what deck you have
Apr 19, 2009 | Alpine CDA-7892 CD Player
Remote wire?
The remote wire on the jvc unit is blue/white stripe if that isn't there it's the blue wire
Apr 08, 2009 | JVC KW-AVX800 CD Player
Trying to install a remote start & keyless entry. I need to know where all the wires from the ignition harness go too???
First you will need to research your vehicles under-dash wiring schematic to identify your object wires, color code and function. The schematic may be found in a Y.M.M.(year,make & model) specific, electrical wiring manual. A related search on the internet, or at your local auto dealerships parts department. Then cross-reference and record your vehicles color coded leads to the remote starts color coded leads with respect to their function.
Hope this helps,,,Good luck
Aduz
Mar 27, 2009 | Crimestopper CoolStart(TM) 2-Way Remote...
The remote wire is not blue wat color is it
it is blue or yellow or its the only odd color
Jan 05, 2009 | Panasonic CQ-C1101U CD Player
Kenwood KDC-MP208 Car CD/ MP3 Player Logo
20 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
