Question about Hotpoint First Edition FEW12 Front Load Washer
Where is the elusive filter located? I thought it was hiding under the flap thing at the bottom but I can't for the life of me work out where it is
It smells and I've cleaned and de-limescaled the machine and pipes so filter is next :)
    New Friend:
If you were to Google "Hot point first edition FEW manual" using Firefox, the results will lead you to "for Hotpoint FEW washer - Laundry Appliances Manuals" at "laundry.manuals online.com>....> Hotpoint Washer".
Download a free copy of the instructions for Installation and Use for Hot Point First Edition Range User Manual.
I have looked through the manual and there is no direct evidence of a filter as such (common to other machines), but there are details of what maintenance should be followed to clean the machine - not too user friendly but may help.
If you do go to the manufacturers website (Hot point is an Indesit company) you will find that previous buyers have asked the same question as you)
Posted on Nov 17, 2013
2 Suggested Answers
  • 4348 Answers
SOURCE: after starting,water goes into the outlet pipe
The outlet pipe must be routed higher than the top of the washer or it will always drain. this is normal. The leak, however is not, something may be damaged, open and inspect.
Posted on Sep 26, 2010
How do you put a spring into the vertical hinged section?
Best way is DO NOT use the spring.Use a common elastic at the bottom of the folding flap run around the flap to a short small screww you would drill into the plastic under the door.This lasts longer than the spring and when it gets tired,just replace with another elastic,lasts for years and works better.
Jan 29, 2016 | Samsung RF265AA Bottom Freezer French Door...
Clean filter washing macine
With any washing machine the filter is located at the bottom front and under flap unscrew plug.Beware water will come out.
Sep 27, 2014 | Amana Washing Machines
My LG Tromm front loader has an OE error message and isn't spinning. First received the message during a full load of laundry. Had to drain the water from the hose at the bottom and finally got it unlocked...
OE is normally down to blocked drain pipes, mcalpine (connection under the sink) or a blocked front filter. empty the machine and unscrew the filter behind the flap at the bottom right hand side, check for any obstructions, icoins, hair grips etc are normally blocking here
Apr 10, 2014 | LG WM-2277HW Front Load Washer
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
I have a 2007 chevy express truck (3500) and my vents do not work. If i turn completly to high the passenger ones seem to work , but still not properly.
sounds like a flap is stuck or non operative ,first thing to do is check the vacumn pipes that may run to a connection on the firewall,being a euroepeon mechanic i have seen one but for this year then i would expect it to have climatic control via a computer and this allows the vacumn to open the appropiate internal flap to direct the air flow ,just had a thought and it hurt my one brain cell ,is the pollen filter clean??
Oct 05, 2012 | 2003 Chevrolet Silverado 1500
How do you remove the filter to clean it?
Miele machines have a flap to open on the bottom left of the machine. To open this there is a special orange plastic spatular located in the backplate of the soap drawer! Dont use a knife or other sharp instrument or you may scatch the paint damage the flap.
The flap should reveal a screw knob which is the drain filter and also an orange tab. This tab is the emergency door opening device. Very useful if your machine loses electric or other faulty conditions.
loosen the filter and let the water drain (a large bowl might come in handy) after the water quits coming out remove the filter completely, check it for and remove any obstructions. put the filter back on, tighten it so it doesn't leak.
Jan 27, 2010 | Washing Machines
How do you install the air filter
The first step to changing the air filter is to find it. Before opening the hood open the owner's manual and find the page that reveals locations of under hood service points. There will be an illustration that makes it easy to find where the air filter box is. If there is no owner's manual, open the hood and look for either a football-sized box opposite the battery or large circular unit or flat panel box atop the engine. Note locations and types of fasteners, clips, and hold downs before removing anything. Take care in not damaging the air flow sensor. These are often located near or in the air box. If locating the air filter still proves elusive an Advance Auto Parts professional can assist in finding the air box and selecting the right air filter.
Hope this helps.. Advance is FREE help.
Dec 06, 2009 | 1996 Pontiac Firebird
The filter bit at the bottom of the dishwasher, what does it look like? I need to know if i am missing a part?
To remove the filter
Turn the handle anti-clockwise to release the filter combination - 1
a. Lift the filter combination out of the dishwasher - 2
b. Remove any coarse particles and rinse the filter well under running water. Use a nylon brush if necessary.
To clean the inside of the filter, the flap must be opened:
^ Press together the catches in the direction of the arrows -1 as shown,
and open the filter -2 .
^ Rinse all the filters under running water.
^ Then close the flap so that the catch engages.
Nov 17, 2009 | Miele Dishwashers
Hotpoint First Edition FEW12 Front Load Washer Logo
79 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
