Question about Ovens
Inglis ifr4200 - Ovens
I have an Inglis IEE31301. The stove elements work but the oven does not heat up. I cannot find any manuals for this model, and I don't know if it has a oven thermal fuse or a regular fuse that needs...
ovens r simple - turn sw on, element heats up. Except ovens usually have timers on them.
start by verifying NEITHER bake or broil works.
If one does - high probability the other element needs replacing.
If neither do u will need an ohmmeter to trace the open back to the plug. There is a possibility BOTH elements r out, not very likely, but start by ohming out both. Don't know what resistance is but it will be less than 1000 ohms. Without a schematic - and u may find one inside the unit - u will have to physically eyeball the wiring.
Feb 23, 2015 | Ovens
I have an inglis oven model irp8580. I can't find my manual and I want to know how the self cleaning works.
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.inglis.ca/index.php/en/products/cooking/ranges/ivp8580
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.inglis.ca/images/stories/inglis/pdfs/cooking/inglis_ranges_usecare.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there.
See page 7 of the ONLINE USER'S MANUAL for complete detailed instructions on how to carry out the self cleaning procedure.
Please comment back here to this page if you have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Mar 20, 2011 | Ovens
How do I change the bulb in an Inglis oven. Can't
Normally the cover will have an anticlockwise turn thread. Twist the glass cover anti clockwise and it should unscrew.
Jan 04, 2010 | Ovens
Oven wiring diagram or help?
I suggest you post this under Inglis to have a better chance of having an answer
Dec 31, 2009 | Stoves 720EF Electric Double Oven
I have an Inglis stove around 10-15 yrs old. When
Yes you can but not the elements themselves
Nov 29, 2009 | Ovens
My Inglis stove appears to have no insulation between the inner and outer panels of the oven door. Consequently the stove becomes very hot when in use and is dangerous if small children are present. Is...
I am looking at an Inglis range, approximately $479.00 and am wondering if the insulation in the oven door is less than a more expensive stove would have.
Oct 22, 2009 | Ovens
Code : E3 -F1-
I have an Inglis electric stove with a self cleaning oven We turned the left dial to "CLEAN" and when turned the right dial to clean, a buzzer went off. Can you give me any advise?
Oct 17, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Popping and arc-ing in the convection area after turning off oven!  I shut off power immediatly!
I would suggest that you check the oven element, as this is about the only thing that could cause the problem.
Plz rate my comments.
Thanks.
Jan 19, 2009 | Bosch HBL3420UC Electric Single Oven
Ovens Logo
19 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
