Question about Holmes HM2060W Humidifier Filter Wick 12-Pack
HOW DO I CLEAN A HOLMES HM 2060W - Holmes HM2060W Humidifier Filter Wick 12-Pack
Holmes 2060w runs but no water is evaporating
change the filter and check for fan moving to circulate the air in the unit
Nov 24, 2013 | Holmes Products Humidifiers
I NEED A MANUAL FOR THE HM 2060W
This solution was posted by timbomullet6 and it looks the same
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Nov 16, 2013 | Holmes HM2060W Humidifier Filter Wick...
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
I have an HM 495, the past 4 days it has been working fine. Now there is no mist coming out and it seems to be spilling water out of the back of the base. What is the problem? I have not been using warm or...
When this happened to me, I took the tank into the bathroom to look at the bottom and then I tried to turn the knob and it wasn't all the way tight. After I tightened it, I put it back on the base and the mist started right away.
Jan 14, 2011 | Holmes Products HM495-UC Humidifier
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 06, 2011 | Holmes Products Warm Mist HM5700...
We have an HM 1740 Family Care humidifier. The reservoir filler cap is broke. Can I get a replacement? M. Frauwirth
Hello! I found this link where you can buy the filler cap for $6.99. I hope it's still available!!!
http://www.appliancefactoryparts.com/humidifiers/holmes/hm1740.html
Dec 30, 2010 | Family Care HM730 Humidifier
How do i clean the fan blades on the holmes humidifier
I am assuming a lime buildup from evaporated water. Use vinegar or drip coffee maker cleaner.
Jun 14, 2009 | Holmes Products Cool Mist HM3500...
I can't remove the grill above the fan so I can clean the blades
I have a Holmes cool-mist One-Touch Humidifier, and you can't reach the blades to clean them, and you can't take the console apart. I finally decided to use two spray bottles and clean and them rinse the Humidifer while holding the console upside down and over a sink. The one bottle you could fill with any mild cleaner plus a lot of water to dilute the cleaner. Maybe dishwashing liquid (not the dishwasher stuff), or a little bit of ammonia, or rubbing alcohol, or vinegar. Spray that on the blades while the machine is upside down, and a lot of sooty dirt drips out. Then rinse with another spray bottle full of plain water. Leave the console upside down on a towel to drip-dry. This is also how you can clean silk flowers that collect dust.
Mar 07, 2009 | Holmes Products Cool Mist HM3500...
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Apr 07, 2008 | Holmes Products HM5250-UC Humidifier
Holmes HM2060W Humidifier Filter Wick 12-Pack Logo
54 people viewed this question
Top Holmes Humidifiers Experts
donshafer
ray gallant
Bill Boyd
Are you a Holmes Humidifier Expert? Answer questions, earn points and help others
