Maytag Neptune washer stops working, gets nF code. We changed the hoses and cleared the filters, but washer still won't fill properly. What do I check next?
    Sergeant:
    Champion:
  • 223 Answers
Hi try testing the inlet valve. If you feel confident to try this: 1 disconnect machine from electrical supply 2 switch it on and off a few times 3 remove machine lid and locate the inlet valve 4 remove the two wires from the inlet valve noting which way they go round 5 using a 9v battery connect it to the inlet valve there should be an audible click each time you touch the contacts. If there is no click I would suspect a faulty valve. Hope this helps.
Posted on Nov 16, 2013
MAYTAG NEPTUNE WITH NF SYMBOL
Symbol - 'Washer has tried to fill' Check water faucets & hoses for kinks. OR call Maytag 1-800-688-9900. Happy Washing!!!!
Nov 02, 2016 | Maytag Washing Machines
Maytag neptune washer
Check the filter screens. At the water hose connector there should be a screen just inside. Clean it with a stiff toothbrush.
Nov 16, 2013 | Washing Machines
HOW TO FIX NF CODE IN MAYTAG WASHING MACHINE
Hello & Welcome to FixYa
NF error in your Maytag is displayed due to no fill condition, when the washer tries to fill but is unable to nf is displayed. Please check the water inlet valve for any clogs and obstructions, you can also clean the inlet to solve the issue. Please get back to me if you have any other questions.
Kevin
Oct 02, 2011 | Maytag Neptune MAH5500B Front Load Washer
My washer gives an nF code. I have disconnected the hoses and cleaned the screens and hoses. Still get error. I believe it is clogged where the hose enters the washer at the inlet valves. How do I remove...
Hello,The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad.
Thanks
May 28, 2010 | Maytag Neptune MAH5500B Front Load Washer
It is displaying a nf and stopped working
NF means No Fill. Check inlet valve screens at the mix valve where hoses attach to machine. If there is nohumming noise at fill time, you will need to replace the inlet valve.
May 18, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune washer will stop working and
HI, this error code is signaling an issue with the fill actions. Your washer seems to be having problems when it try's to fill the tub with water.
First, make sure there's water getting to the washing machine. Make sure the water faucets are open all the way.Check for kinked hoses as well.
If the hoses are fine and, the faucets are fully open, this will confirm a inlet water valve malfunction. you will need to replace this failed component in this case. it has failed.
Jun 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Model MAH8700aww washer
The "nf" code is a "no-fill" fault. This indicates that your washing is not getting water supplied to it, or the pressure isn't substantial enough to complete a fill. You need to, first, make sure the water supply is turned on. Second, if the water IS turned on, and you're still not getting anything to your washer, you may have a fill valve problem. The fill valve is what both your hoses connect to on the back of the machine. It can become clogged with sediment over time (especially, if you have hard water or well water). Turn the water supply off and remove both hoses from the back of the washer. Check both these hose connections for clogs in the filter screens. If they are clear, then more than likely the fill valve has gone bad. I hope this helps you.
Dec 12, 2008 | Maytag Washing Machines
Getting nf code on final spin cycle
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Nf code
Nf pops up on the screen & the washer stops
May 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
