Question about Sewing Machines
White 534 gears
I need to find a place to buy the gears for my serger. Took it to repair shop and was told i need them but they are not available. HELP
  • Sewing Machines Master
  • 7,365 Answers
Check with a1sewingmachines.com or
sewvacdoctor.com
you'll have to call them or email them--thru their contact us section
Posted on Nov 16, 2013
4 Suggested Answers
maklean
  • 1665 Answers
SOURCE: needles break and machine jams
TIPS FOR SUCCESSFUL SERGING WITH WHITE SERGERS
http://www.whitesewing.com/PDFs/Serger_Tips.pdf
Posted on Jun 20, 2008
SOURCE: White Speedylock 1500 Serger Manual
I have a 1500 with a manual. I could copy the manual and send it to you. Email me at allgrunnfam@comcast.net
Posted on Jan 20, 2009
danforddan1
  • 192 Answers
SOURCE: I need instructions to Thread a White Super Lock 534 Serger
I hope this helps. there a lot of other vidios you can try as well. DFD
Posted on Apr 22, 2009
I have a brand name: White Super Lock 534 Serger Machine. It uses Twin Needle for interlock stitches. Where Can purchase them?
You can get twin needles at most all sewing stores
Do not buy cheap ones. They are not tempered
Nov 29, 2017 | Sewing Machines
I have a White super lock 534 Serger that I just Inherited. I cleaned it up and pluged it in I found out it's not getting any power to either the motor or the lightbulb . Do you have any ideas ?
Make sure that it is plugged in completely. Otherwise, the foot control/power cord may be faulty.
P.S.--hope you were able to oil it also. Tri-Flow Synthetic Lube every place that metal parts rub other metal parts--no plastic gears or belts.
Feb 12, 2017 | Sewing Machines
I have a white speedy lock serger model 7340. I completely pulled all threads out and now trying to re-thread new thread. I have tried around 15 times. It will not loop. Threads don't interlock at all
Be sure that you are threading each thread in the correct order. The manual should have those instructions.
ALWAYS RAISE the presser foot when threading the machine!!!! For most machines, the upper looper is threaded first, the lower looper second (the lower looper thread finishes by draping OVER the top of the upper looper and then pulled toward the back of the machine), then thread the needles. Give each thread an extra little tug when threading the tension disk to make sure it is seated completely.
Even if you are unable to locate a tutorial for your particular machine, most models from the same era will thread the same.
Don't be surprised if it doesn't work the first, second, or even the third try. It took me most of a day to get mine threaded correctly the first time!!! Patience!
How to Thread the White Superlock 534 Serger Serger Machine Series Ep 2
How to thread White Superlock serger
Sewing Machine Instructions White Speedylock Differential 1800
You can search YouTube for other videos.
Jan 06, 2017 | Sewing Machines
Need the manual for model 534?
SINGER 534 MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Singer Manuals > Sewing Machine > 534
View and Download Singer 534 manual online. Stylist Sewing Machine. 534 Sewing Machine pdf manual download.
[PDF]White Sewing Manual Model 534
www.masepmadit.com/white-sewing-manual-model-534.pdf
vw instruction manual, white 534 serger: sewing parts online understandable ... techmanual white superlock serger model 534 repair manual compiled pdf.
Jan 07, 2016 | Sewing Machines
Why is my handwheel hard to turn and making a squeaky noise?
Sounds like possible thread in the gears, or the wrong oil might have been used to oil the machine. Sewing machine oil (clear oil) should be used for oiling the machine. I use an oil called Tri-Flow Lubricant which is available at your local bicycle repair shop.
May 28, 2014 | Husqvarna Huskylock Computerized 910
White model 534 serger
Your serger most likely need to be oiled. It is important that you keep your serger clean and oiled. More so than your sewing machine. If this is a new squeak, you can try to oil the area that it is coming from yourself if you can get access to it. If it is not a new squeak it is possibly coming from the motor or the belt and then I wouldn't suggest to oil those parts. If you can't get to where the squeak is at bring it to a repair person and they should be able to take care of it.
Sep 13, 2013 | Sewing Machines
Find a gear part to repair my Bernett 334d
Has the horizontal shaft gear (white nylon gear) inside your overlocker failed? Does it look like this?
http://www.sewingpartsonline.com/horizontal-shaft-gear-bernina-bernette-50141103.aspx
My repair man obtained this part from Bernina and was able to repair this although it is a labour intensive repair requiring pulling down the whole machine to do. But the part itself was only $US38.
You can buy from sewingpartsonline as per link above.
Or you could ring Bernina head office in your country and talk to someone about it as I was initially told my machine was unrepairable as this part was not available by a local store who wanted to sell me a new one. I guess in light of the 4-5 hour repair time, this is probably a valid call if you buy a new plastic serger but I love my Bernette and felt it was worth repairing, not junking it. It is now 5 years later and still going strong since that repair. My OSMG (old sewing machine guy) Ken told me that the nylon gears sometimes will just crack, even if the machine hasn't had lots of work, just plastic ageing.
Hope this helps you - please rate me 4 thumbs up if so. Cheers
Jun 22, 2011 | Bernina Sewing Machines
Need belt for white super lock serger model 534 a serial number 87351382
Try Ron over at http://www.a1sewingmachine.com I have tried calling their parts number over at White and it just rings. Good Luck!
Jun 28, 2009 | White Sewing Superlock 1934D Mechanical...
Sewing Machines Logo
52 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
