Holmes HM2060W Humidifier Filter Wick 12-Pack Logo
Theresa Klatte Posted on Nov 16, 2013
CLEANING AND FILLING HOLMES HM-2060W HUMIDIFIER
1 Related Answer
Paul
  • 225 Answers
  • Posted on Nov 16, 2013
SOURCE: I NEED A MANUAL FOR THE HM 2060W
This solution was posted by timbomullet6 and it looks the same
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Here is all the info I found Ser # 50908272 Holmes Humidifier HM-300
It depends on how humid it is in the conditioned space, how well sealed the conditioned room is, and how high you have the humidifier set. If you have low humidity in your conditioned space and you are asking for a higher humidity number, it could go through quite a bit of water. If your room is not sealed well, it will allow lower conditioned air into the room and put a larger demand on the humidifier
Jan 21, 2018 • Humidifiers
Holmes 2060w runs but no water is evaporating
change the filter and check for fan moving to circulate the air in the unit
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
1helpful
We have an HM 1740 Family Care humidifier. The reservoir filler cap is broke. Can I get a replacement? M. Frauwirth
Hello! I found this link where you can buy the filler cap for $6.99. I hope it's still available!!!
http://www.appliancefactoryparts.com/humidifiers/holmes/hm1740.html
4helpful
Humidifier does not reset
According to Holmes, one of the causes of the Reset light staying on is scale buildup on the heating element.
Remove Scale: Allow to cool before maintenance.
1. Repeat steps 1-5 in the Daily Maintenance section.
2. Clean the base by partially filling the base with one
8-oz cup of undiluted white vinegar. Let solution stand
20 minutes, cleaning all interior surfaces with a soft
brush. Dampen a cloth with undiluted white vinegar
and wipe out entire base to remove scale.
3. Rinse with clean warm water to remove scale and the
white vinegar solution before beginning to disinfect
the tank.
4. Wipe the heating element clean with a soft cloth after
it has had chance to cool.
If the scale has really built up it might take longer than 20 mins for the vinegar to get rid of it and you might need to refresh with new vinegar.
Your Manual can be found at this link:
http://www.holmesproducts.com/Manuals/Holmes/HM5250-UC_English.pdf
Good Luck.
Top Holmes Humidifiers Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Holmes Humidifier Expert? Answer questions, earn points and help others
