Question about Amana ACM1580AS Microwave Oven
Was working then made a raspi noise now nothing works
    Problem Solver:
  • 15 Answers
Sounds like you might have a problem with metal in the oven. Look inside the oven including the "ceiling" and see if the finish has worn off, leaving bare metal. If so, wash that area thoroughly, dry, sand lightly. Then apply some appliance paint that comes in tiny bottles and costs about $4.
Posted on Nov 17, 2013
The start pause button does not work.microwave keeps running. Press clear/off
The key pad module is faulty.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 21, 2016 | GE Microwave Ovens
GE Spacemaker XL1800 Microwave
see for the turn table obstacle of any screw or something else.
Aug 04, 2008 | Samsung MW1030WA Microwave Oven
Maytag model MMV4230DS00, everything seems to work but nothing heats, no humming or noises.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Aug 05, 2011 | Maytag MMV4203D Microwave Oven
Plugged in my Emerson MW7300W. Light works, won't cook
there is a thermal (white ceramic) fuse located right under the cover on the top of your microwave replace it.
an electronics part store should stock it.
Feb 01, 2010 | Emerson MW8777W Microwave Oven
MW 8168B - Inop
some mic's have fuses check that out
Feb 15, 2008 | Emerson MW8168B Microwave Oven
Microwave just went dead
If there is no display and nothing works it may be as simple as a blown fuse. Try that first but unplug the unit before you do anything.
Oct 02, 2007 | Goldstar MA-7100 Microwave Oven
Spacemaker 1800 Turntable
If the noise goes away when you turn the turntable off, it sounds like you have a turntable drive motor that is going bad. They are fairly easy to replace and not terribly expensive. You can access the motor by leaving the oven in place and UNPLUGGED. Remove the bottom panel. You will need to remove the turntable coupler (the plastic piece that spins the glass carousel) and remove a few screws in order for the motor to come out through the bottom of the oven. There should also be a quick connect plug that plugs into the motor. The motor runs about $35 and the turntable coupler (if you wish to replace it as well), runs about $8. The part numbers are 769741 and 769278, respectively at repairclinic.com. I hope this helps you.
Jul 07, 2007 | Kenmore 66469 / 66462 / 66464 Microwave...
Microwave does not heat
If you don't have electronic experience is to dangerus, you will needs a Technician to chek: If 110 volts sypplying the big transformer, if yes check the output of this transformer, if have high voltage the transformer is good, then have to check: Magnetron, high vontage diode and big capacitor. I'm sorry this is not easy to no experience person. I'm sorrry for my English not so good. I hop you solver ou problem.
Jun 25, 2007 | Whirlpool GT4175SPS Stainless Steel 1200...
UPDATE: GE Spacemaker XL1800 Microwave
JVM1850BD002 is a correct model number. This is a GE made by Samsung. It sounds like the motor or coupler is bad. More likely the motor. If you grab the motor shaft and try to gently turn it, it may grind or slip a lot. That's a sign of a bad motor. If the coupler is bad, it will be cracked or broken, causing it to slip on the motor shaft or the turntable itself. The coupler is reference 40, and the motor is reference 43 on this handy exploded view drawing: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00016500/00016593.p01.pdf (copy & paste whole URL) Here is the GE part price info on these two parts: DESCRIPTION DRAWING PART NO. PRICE MOTOR-SYNCHRONOUS 43 WB26X10038 $46.00 COUPLER 40 WB06X10144 $8.75 If the motor is bad, you might be able to find the Samsung part number printed on the motor label and look it up at http://www.samsungparts.com They often have parts for far less than the expensive GE parts.
Dec 01, 2006 | Samsung MW1030WA Microwave Oven
Your turntable motor is shot. It's simple to remove and replace. you don't even have to take the microwave out of the shelf. To remove it take out seven screw around the perimeter of the bottom. Lift up on back of bottom to get over clips on the back. Remove the two screws holding the motor in and detach the plug. Find a electrical repair shop for you make pick it up and replace it. When replacing it take out plate and hold plate key down and align flat side of shaft on motor with the plate key.
Nov 30, 2006 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
foster_mommy
Level 1 Expert
Jim Thurston
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
