Question about 94-00 Ford Econoline Van Side View Mirror - Left Driver 1994 95 96 97 98 99 2000 F4UZ 17683 A Door LH Replace
Won't run at all now
My 95 ford E150 came to a stop sign started to run rough and cut off, after about thirty seconds of trying to restart it it started and ran for about ten seconds and cutoff again, now it wont run at all. Its getting fuel and spark but does not want to start, any idea what could be wrong with it?
    New Friend:
    Problem Solver:
  • 7 Answers
CHECK FUEL PUMP OR FUSE FOR PUMP
Posted on Nov 16, 2013
When i start my 1999 e-150 van sometimes it idles rough for 20 seconds then its ok.should i put some fuel cleaner in to clean the system?
You need to remove and clean the air bypass idle speed control valve and the throttle valve and bore, they get gunked up from combustion "blow back" and that causes stalls and rough cold running. Use only CRC Throttle Valve cleaner (any auto parts store) on both parts, carb spray will destroy the non stick coating inside the parts.
Nov 23, 2016 | 1999 E150
I have a 2002 Ford Exlorer. It would idle rough at stop signs and stop lights like it would cut off it we did not give it a little gas. Yesterday, I was driving it up a slight incline on a street and
Check for OBD Codes
Check & Test the Battery
Check Fuel Pressure at the motor
or on scan tool data
Check for Vacuum Leaks
Get caught up on Preventative Maintenance
The fact it ran rough, tells you it needs work
& the shutting off is a different issue
Nov 07, 2014 | 2002 Ford Explorer
Runs rough dies
change the fuel filter and check the fuel pressure
May 25, 2013 | Ford Expedition Cars & Trucks
Car intermittantly shuts off and won't restart for an hour or two
I owned a 1988, Oldsmobile 88, that did that. after several hundred $ of "repairs" - It was that pump IN the gas tank that had gone bad.
Apr 27, 2017 | 1999 Ford Taurus
1999 ford econoline van both rear doors are locked and cannot open from inside or out?
I have a 1999 Ford e150 van and the van runs good on the highway and rough on the city street. tries to stall at red lights and stop signs. I took it to a garage and the computer says it is running lean on both banks.
EGR sensor, just replaced it an hour ago and started to remove the egr valve. I can't figure out how to get out the bottom bolt. and is there anything else holding the egr valve?
The garage said to use carb cleaner and spray it out. they told me to ry this before you buy a new one. It's 11:30 pm and I wish i would have just got a new one. I don't want to go through this again.
Help me get this off and if possible direct me to some photos,
Thanks,
Bob
videoguybob@mail2bob.com
Mar 04, 2011 | Ford Econoline Cars & Trucks
I want to know what cause the problem like
Does it not restart or does it start and then die as soon as you put it in gear?
Mar 11, 2009 | 1991 Pontiac Sunbird
No spark
What about battery and alternator (serpentine belt).
Dec 05, 2008 | 1992 Mazda MX-3
Stalls / Dies / dead
this engine fuel pump prassurae low. it fuel pump celan. Your problem sovel
Jul 13, 2008 | 2003 Ford E150
94-00 Ford Econoline Van Side View Mirror - Left Driver 1994 95 96 97 98 99 2000 F4UZ 17683 A Door LH Replace Logo
160 people viewed this question
Top E Series/Econoline Van Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an E Series/Econoline Van Vehicle Part and Accessory Expert? Answer questions, earn points and help others
