Question about HP Officejet 5610 All-In-One InkJet Printer
Ink cartridges keep popping out when i close the printer door
Changing ink cartridge and it keeps popping out
    Scholar:
  • 155 Answers
The cartridges are not seating all the way - are you sure all the tape has been removed from the cartridge? Also, use a flashlight and look on the ink cartridge carriage - make sure there's no paper of tape sitting on it that would keep the ink catridges from seating properly. The ink cartridges should go in and you should feel them click into place.
Posted on Nov 16, 2013
  • 106 Answers
SOURCE: Keeps stating ink expired
i guess your printer has reach the printing warranty.. try to search in the web on how to reset your printer, ^^
Posted on Feb 16, 2009
  • 214 Answers
SOURCE: printer Align keeps failing after I chnaged the color cartridge
Are all the inks printing? If not you need to get all colours working before correct align can take place Have you tried cleaning the gold cartridge contacts? Wth a little distilled water, cotton bud and then let dry before reinstalling
Posted on May 29, 2009
SOURCE: HP c6280 Won't load ink cartridges
Per HP:
Hold “print photos” button and “red-eye removal” buttons together, release
ø Then press the “red-eye removal” button, release
ø Then press the “print photos” button, release
ø Then press “red-eye removal, release
ø Scroll to “resets menu”, click ok to select
ø Scroll to “Options” semi-full reset, ok
The printer then powers off and wait a couple of minutes. I believe the printer turns back on (or maybe the user needs to power back on after a few minutes). The refills then work.
Posted on Jul 03, 2009
SOURCE: i changed my ink cartridge, but the top cover
Lift the printer cover. There is a slot on the right side by the ink cartridges. Push the end of your little finger into the slot. Close the lid. I know this sounds lame, but it has helped me many times. It seems the latch will stick and this usually unsticks it.
Posted on Oct 08, 2009
don_farr
  • 1018 Answers
SOURCE: orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Posted on Oct 22, 2009
My printer keeps telling me that I haven't closed the ink cartridges door
The ink catridge door sensor as been damaged.
Clean d sonsor and check sensor connecting wire
Jul 14, 2016 | Office Equipment & Supplies
My HP Officejet 5610 All-In-One InkJet Printer keeps randomly popping up with cartridge error. Take the out then reinsert to no avail. changed with new. still keeps popping up
If the "new" cartridges were brand new HP oem cartridges, there are two things I would do. First, take out the cartridges and inspect the contact area (where the electrical in the printer meets the electrical on the cartridge) and make sure there is no dirt or ink on the contacts. Secondly, remove both of the cartridges, close the lid, and pull out the power cord while the printer is on. Wait at least 10 minutes, plug in, power up and wait until it is done making noises. Open the lid and insert the black cartridge first(important!) and then the color. If this doesn't take care of the issue, replace the printer. (If you're sure the carts were brand-new)
Sep 29, 2010 | HP Officejet 5610 All-In-One InkJet...
How to open printer to change cartridge?
In order to replace the cartriage, please follow the steps below:
1 Keep the printer on.
2 Lift the printer (scanner unit) until the scanner support keeps it open.
The ink cartridge carrier moves and stops at the loading position unless the printer is
busy.
3 Squeeze the tabs on the cartridge lids, and then lift the lids.
4 Remove the old cartridges.
5 If you are installing new cartridges, remove the stickers and tape from the bottom of
the cartridges.
6 Insert the new cartridges. Make sure the color ink cartridge is secure in the left carrier
and the black cartridge is secure in the right carrier, and then snap the lids closed.
7 Lift the printer (scanner unit) and push the scanner support back while lowering the
printer (scanner unit) until it is closed.
Sep 15, 2010 | Dell A920 InkJet Printer
I have an hp photosmart 7760 printer. Just put in new ink cartridges and one keeps popping out when I close the top and I can't get it to not pop out. Help
Are you closing the latch over the cartridge once you install it? One latch is closed over the cartridge which insures proper seating it can't pop out.
Make sure latch is closed and try again
Jun 29, 2010 | Office Equipment & Supplies
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
New Cartridge error message
Follow the steps below to remove and replace the empty ink cartridge.
  1. Turn the printer on.
  2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00819080.gif
  3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00819081.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
    NOTE: Theink cartridge areas are color-coded for easy reference. From left toright, the ink cartridges are black, yellow, light cyan, cyan, lightmagenta, and magenta.
  4. Pull the ink cartridge toward you out of it's slot to remove it. Figure 3: Removing an ink cartridge c00819082.gif
  5. Remove the new ink cartridge from the packaging.
  6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    NOTE: Makesure that the ink cartridge is inserted into the slot that has the sameshaped icon and color as the ink cartridge. The copper-colored contactsshould be facing the printer as the ink cartridge is inserted. Figure 4: Inserting an ink cartridge c00819083.gif
  7. Press down on the gray latch until it clicks into place. Figure 5: Closing the gray latch c00819084.gif
  8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
  9. Close the ink cartridge door.
after Doing this all Follow the next step :-
Please Try This, I am sure it is going to workout.
Resetting the All-in-One
Press the On (fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Oct 21, 2008 | HP Photosmart C5180 All-In-One InkJet...
Put new ink cartridge and can't install
Replacing your cartridge:
  1. Make sure the printer is switched on.
  2. Pull the operator panel forward and open the cartridge access door. (Note: The cartridge carrier moves to the loading position, unless the printer is busy).
  3. Pull the old cartridge forward and then lift it out.
  4. If the cartridge is new, remove only the sticker or transparent tape on the bottom of the Cartridge.
  5. Insert the cartridges into the carrier and push back firmly until they snap securely into place.
  6. Close the cartridge access door and the operator panel.
  7. From the operator panel, press Options to select the cartridges that were changed.
  8. Press Start (Start/Yes), Options to select the cartridge type installed.
  9. Press Start (Start/Yes).
Sep 16, 2008 | Office Equipment & Supplies
My C3100 HP all-in-one printer prints a test page everytime I want a single copy. How can I print before wasting ink on a test page?
cannot load new ink cartridge c 3150 black cartridge keeps popping out when you close acces door help thanks harry
Apr 23, 2008 | HP Office Equipment & Supplies
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Error message 50c on printer
I had the same error message 50c and "color Ink low". I knew that I still had Black Ink, and that is what I just needed for the moment, so I removed the color Ink cartridge and it started working. You'll get a message 'print cartridge missing' but just press continue.
Hope this helps,
MPTMPeru
Nov 11, 2007 | Dell A940 All-In-One InkJet Printer
HP Officejet 5610 All-In-One InkJet Printer Logo
120 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
