Question about Sears Heavy Machinery
Lazy boy chipper vac
I have the 3.8 Tecumseh motor. its a craftmans lazy boy vaccum/chipper. my question is, i only see the gas tank, that reads"gas only". i see no oil tank. so if the gas tank isnt a mix of both gas and oil, and theres no oil tank, does this mean it only takes gas, and no oil?
  • 1129 Answers
SOURCE: How do I clean the fuel line on troy bilt 5hp chipper vac?
unscrew the nut on the bottom of the carburetor and remove the float bowl it must be emptied and cleaned , debree and water gets into the bowl and blocks of fuel flow reinstall the bowl and start, some carbs don't have a float bowl requiring you to remove the gas tank and carb which is a more involved cleaning.
Posted on Jul 14, 2009
rwvanlue
  • 486 Answers
SOURCE: I need parts for chipper vac
parts are NLA Murray has gone bankrupt, assumed by Briggs & Stratton. Many Murray parts are NLA
Posted on Nov 08, 2009
  • 51 Answers
SOURCE: i have a troy built chipper schredder vac built by
start at one and a half turns each ,run at full throttle turn outhigh speed screw (bottom) until it starts running flat, turn back untill runs clean. same procedure for low speed screw but at idle speed .when done turn throttle to high speed if boggs open low speed screw alittle bit at a time untill accelerates with out bogging hope this helps
Posted on Aug 10, 2010
  • 640 Answers
SOURCE: I have a Yard Machine
If you have the same 8 HP Tecumseh engine that I do then if you look at the the engine, squat down so that you are looking at the recoil starter, then look for a label on the left side of the shroud (cover) down low and you should find the model number of the engine. Record that number and send it to me so I can check it. After I check it I will tell you what website to go to in order to order it or how to get the part number so your local small engine repair shop can order it for you. You can also just take the engine model number to the local small engine repair shop and tell them what you want to order and they should be able to get it for you.
If you go directly to the local shop, I hope you get it going soon.
Posted on Aug 05, 2011
SOURCE: I have a 15 year old chipper-vac with an 8 hp
10W-30
Posted on Nov 30, 2011
I have a troy built chipper vac that starts but won't stay running it has gas and new spark plug
How old is the fuel in the tank and also look into the tank for water from condensation. If the gas is older than 2 months drain the tank and the carb bowel.
Nov 06, 2015 | Troy Heavy Machinery
Is it hard to change a magneto on a 5.5 hp Tecumseh engine?
How old is the gas in the tank? If it is older than 2 months drain it out and put in fresh gas and try again. Have you seen spark jump across the spark plug gap? To check for spark I use a spark checker. One end goes to the plug and the other to the spark plug lead. If you have spark you see a light flash which is more easy to see.
Sep 16, 2014 | Tecumseh Engine 5.5hp Horizontal OHV MTD...
I have a Yard Machine chipper shredder with a tecumseh motor with the 3 way feeding system ... I need the gas tank for this machine ... any idea where to find one?
Aug 05, 2011 | Yard Machines Electric Chipper/Shredder
Have a Troy-Bilt Chipper/Vac model # 47282 5hp sp, the Carburator needs to be replaced, I cannot find a part # for it, or where one can be purchased, please help
I believe the carburetor part number for your model is 632631. I have the same TroyBilt chipper/Vac. It has a Tecumseh H50-65582W engine. A good parts diagram can be found at
http://www.outdoordistributors.com/pdf/Tecumseh/TECUMSEH-MODEL-H50-65582W-PARTS-LIST.pdf
If this is the right part, you can buy it at Jacks Small Engine parts for $79
Good Luck!
Dec 12, 2010 | Troy-Bilt Chipper Shredder
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Jul 14, 2009 | Troy Bilt 24b - 060f766 5hp Chipper...
I need a manual for a Lazy Boy chipper/vac model 47030
Have you tried to look it up online at the Lazy Boy website? I have been able to locate several parts and manuals there.
Jul 13, 2009 | Garden
Heavy Machinery Logo
95 people viewed this question
Top Sears Heavy Machinery Experts
lnbn1975
Matt Olenzek
Matt Olenzek
Are you a Sears Heavy Machinery Expert? Answer questions, earn points and help others
