Question about Imation Turtle Case Multi-media
Imation multi media player doesnot detect 2TB USB hard disk, It works with other USB hard disks, ie, 80Gb.
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: problem with burning dvd on imation dual layer dvd burner
You seem to have a related problem, you can't burn cd's and you cannot install windows without an error. Either your hard drive has a bad sector where it keeps trying to write the data or your dvd drive has a reading error. Firstly check your hard drive for errors, right click on your 'c' drive and down to properties, then click on tools tab, then error checking. This can take quite a while, so be patient. Secondly, there have been numerous updates from Nero especially related to Service Pack 2 so download the latest updates from their 'Ahead Nero' website, they are free as you are'nt upgrading just updating. Your ratings are important
Posted on Nov 23, 2006
  • 10406 Answers
SOURCE: my imation 320 gb 2.5
Either the USB ports on your computer are not working
(try some other USB device in those ports to disprove this)
or the USB ports are supplying insufficient voltage/amperage to your Imation device,
such that it does not operate.
Posted on Nov 13, 2010
  • 917 Answers
SOURCE: Hi.My Imation Apollo 2.5" 500GB
With any luck, it may just be due to a loose cable or connection inside. You need to open the unit and make sure everything is properly connected.
Posted on Mar 14, 2011
SookCampton
  • 52 Answers
SOURCE: my imation portable hard disk
Yourhard drive is properly dead.However there are stillhopes for hard drive data recovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in your freezerfor 24 hours that will do the trick. While it's still cold, plug it into yourcomputer.And you may be able to view it in 'my computer'. And you may actquickly,because you may only have 20 minutes to recover your data off it andafter that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how to recover data from hard drive.
Posted on Sep 14, 2011
Imation HDD Pro Media player 500 gb. orange light flashing but not detected by my laptop.
You "killed" it -- either the USB-to-disk-drive adapter inside the case, or the disk-drive inside the case.
Remove the disk-drive from the case, and install it in a replacement case (with replacement power-supply).
May 09, 2015 | Imation Computers & Internet
Imation multi media 2.5: hard disk 250 gb
Hi. What is needed is a codec pack upgrade. Here is Imation's support page. They also have a phone number you can call: https://support.imation.com/app/home Good Luck
Feb 13, 2014 | Computers & Internet
I have a WD media player and my HD crashed recently. I installed a new one but i now get an error message saying that my HD is not detected yet it works fine on the PC - please assist.
If it works OK on you PC and not in the WD, it suggests to me that you have the disk incorrectly formatted. Most media players use a Linux format not a windows format (fat or ntfs). Try deleting the partition in the PC and then format it with the WD. I presume that you replaced it with the same size disk as many of them will not use anything larger than the original size.
Dec 05, 2013 | Western Digital WD Elements Play v2...
3tb external imation expert d300 not working with windows xp
Windows XP does not have support for any disk-drive larger than 2TB. So, your 3TB disk-drive will not work. Upgrade your computer, or buy a 2TB disk-drive.
Jan 09, 2013 | Imation Apollo Expert D300 External Hard...
CAN AND CAN'T CONNECT IMATION TO MY PC!My laptop does not detect my Imation Grand Entertainer HDD Multimedia Player when I connect it to the USB portal. I took it and my laptop back to the shop a
This problem is caused by hard drive only. your hard disk is not working properly so open the cover and remove circuit board then you can see the hard disk attached with circuit board .please remove the HDD and connect if you have spare HDD(2.5 inch HDD also you can use) please connect and see it will work.my grand entertainer is working with 2.5 sata HDD now
Dec 03, 2012 | Computers & Internet
Hi, I have a segate barracuda 7200.9 160 gb hard disk which was working fine with my desktop but when i am connecting it to laptop thorugh USB it is showing in device manager as portable media.. showing in...
I would suspect that Windows is screwing things up, your laptop cdrom drive should be "d" drive and your portable usb drive should be the "e" drive. You could try to change the usb to "e" in disk management, failing that I would reboot the laptop with usb drive connected to see if Windows straighten things out.
May 14, 2017 | Seagate 80GB Barracuda 7200.9 SATA s - 8MB...
Hi, my Immation Portable 160GB as soon as I plug it into my computer, the light is on, the HD seems to be working, but on my pc it doesnt even appear on MY COMPUTER the disk to open. I plug it and windows...
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
Jun 17, 2011 | Imation Apollo Portable - Hard drive - 160...
Connect external hard disk IBM travel star 80GB USB port 2
Unless it's windows 98 you don't need a driver. If your computer can't see it, it's probably broken. Try plugging it in to another computer and see if it can see it
Oct 01, 2009 | IBM TravelStar 40GN 40 GB Hard Drive
WD HD Media player damaged my hard drive??
Hi Dear! This problem could be solved through a software. You should use Western Digital Disk Manager, your WD hard disk will work properly after using that your WD hard disk pass all test of the software. When it will pass all test it will work properly and in other condition if it will not pass then you should try again so that the software will fix the error and it will made workable.
Thank You
Jul 24, 2009 | Western Digital My Book Premium ES...
Why can'tm I play DVD+R DL/2,2x 8 Hr discs on my SharpDV-RW 250x Recorder
Does your player support the disk type you have???
Minus disks are different to Plus disks in respect to the machines they will work in and the formats you put them on to the disk my only be read by the machine the writes them
Looks like your disk type could be a mismatch,
Check them and let me know thanks
Jul 21, 2008 | Imation 16575 2.4x DVD+RW Storage Media
Imation Turtle Case Multi-media Logo
Top Imation Computers & Internet Experts
Raj Patel
Jax Planet
Jax Planet
carey w mason
carey w mason
Are you an Imation Computer and Internet Expert? Answer questions, earn points and help others
