Question about Guillemot Elite Q400 SL3000UL CSW200 Hercules Logic Board
How to reset Elite Q400 SL3000UL CSW Hercules Logic Board
My elite SL 3000UL gate opener stops working. I want to try reset the system to see if it will solve the problem.
Gate will open pushing open button but cant use remote
General answers only, sorry. Look for loose or corroded connections, especially where wire nuts were used. Reprogram the remote receiver. Disconnect power to the receiver for a short time. Reconnect and reprogram. I hopes that any of this helps. I have operators to the much like witch craft, a black science!
May 10, 2016 | Elite Gate Opener Sl3000 Slide Gate...
My elite gate won't close. the charge ok led light is not on. checked everything and it's ok. switch limit switch on both sides works fine except when trying to close, it won't run.
If you disengage the motor does the gate slide easily? if not that could be the problem, most gate control boards have a sensor that detects the current drawn by the motor, if the gate hits an obstruction or is jammed the motor draws more current and the sensor stops the gate moving. It could also be a problem with the safety sensor, to check this locate the safety sensor input on the control panel and bridge the 2 contacts if the gate then works the safety sensor is the problem.
Dec 28, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
Why does my elite opener start to open then stop?
check the overload sensor it might be set too low.
Jul 19, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
1. I have an elite slide gate opener it will open all the way and after a few sec will close. 2. With the remote the gate will not stop and stay in the open position.
the auto close has been set or the motor has been set up in reverse and it is auto reverseing,make sure the gate is opening up all the way, if it is not just help it along and see what happens.
Apr 13, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Holiday Programming
the elite does not have that function, your are going to need to look for a time clock that holds open your gate...... the outside phone system or a programmable time clock that has been added to your gate...... oh this is an old post sorry. :)
Dec 19, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Sliding gate will not close
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
Guillemot Elite Q400 SL3000UL CSW200 Hercules Logic Board Logo
Top Guillemot Home Security Experts
Lawrence Oravetz
Are you a Guillemot Home Security Expert? Answer questions, earn points and help others
