Question about White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
Water heater will not come on 183760-000 - White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit
I have a Rheem 62sv-40d electric water heater. What type of 4500W element do I need?
Rheem have their own spares site and web catalogue in the main link, but also here as well
Rheem Water Heater Parts - Rheem Parts - Rheem Replacement ...
www.supplyhouse.com/Rheem-Water-Heater-Parts-19213000
  1. Cached
  2. Similar
Here you will find a huge selection of Rheem Water Heater replacement parts. These water heater replacement parts can save you from replacing an entire ...
Rheem - Water Heater Parts - Water Heaters - The Home Depot
www.homedepot.com > Plumbing > Water Heaters > Water Heater Parts
  1. Cached
  2. Similar
Shop our selection of Rheem, Water Heater Parts in the Plumbing Department at ... WiFi Module for Select Rheem Performance Platinum Electric Water Heaters.
https://parts.rheem.com/OA_HTML/ibeCZzpHome.jsp?minisite=10165&respid=52926&grp=IBE_M_OTHER
Nov 20, 2016 | Rheem Water Heaters
Water heater leaks
You have to replace water heater.
But you can buy-time if leak is small by turning heater off except when you need hot water. This will give you 30-60 days to shop and find best heater.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To prevent tank from rusting in this manner, inspect and replace anode rod each 2-4 years, and keep water pressure below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 24, 2012 | Water Heaters
Need a manual for a maytag electric water heater. model # HE2950S
More information is needed about this heater.
The label located on side of tank should show manufacturer.
Maytag does not manufacture water heaters.
Maytag is a brand name used to market water heaters made by other companies.
Maytag offers a phone number for water heaters:1-866-362-9898
Other resources:
-If the water heater has electronic control box on top, then following American Water Heater Company manual might be suitable:
http://www.americanwaterheater.com/support/manuals/energysmart.pdf
-Electric water heater instruction manuals can be found on following link:
Each is basically the same, unless there is electronic control box.
http://www.americanwaterheater.com/support/manuals.aspx
-If you have ordinary two-element 240volt water heater and are having problems, or want information on maintaining water heater, then following link is useful:
http://waterheatertimer.org/DIY.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#cleanelectric
Sep 28, 2011 | RELIANCE ELECTRIC WATER HEATER
Service proceedure on Rheem 16225088 .
You posted under typical Rheem tank-type electric water heater, but don't say what service you want to perform.
Listed below are typical actions one takes with electric water heater:
1) Flush tank each 6 months to prevent sediment.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
2) Inspect and replace anode rod.
3) Test electricity from breaker box to water heater
http://waterheatertimer.org/Test-electricity-to-water-heater.html
4) Troubleshoot electric water heater
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
5) Clean sediment out of water heater
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
6) Save money
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
7) Do it yourself information
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 06, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
How do you set a temperture
You posted under tank-type electric water heater:
There are several new types of water heater controls and each set slightly differently:
Open following page to see how to adjust temperature on common models of water heater:
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html
To get specifics for your water heater, look at label on side of tank.
http://waterheatertimer.org/Water-heater-manufacturers.html
To find age of water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
If your water heater is not shown, then add a comment.
If you have tankless water heater, then re-post question with specific brand and model number or refer to product manual.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Feb 11, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
White Rodgers White-Rodgers 1F85RF-275 Thermostat and Wireless Remote Sensor Kit Logo
110 people viewed this question
Top White Rodgers Home Security Experts
Tom Chichester
Heatmeister99
Level 1 Expert
A Hoffman
A Hoffman
Are you a White Rodgers Home Security Expert? Answer questions, earn points and help others
