Question about Lakewood Dryers
15" floor fan switch
On/off switch broke...I want to replace it
How do I check to see if the motor is bad on my ceiling fan?
You bought the wrong switch. Just because it looks the same on the outside doesn't mean it's the same on the inside(switch). I don't know if you have a bad motor but it is a cheap low-end fan only made for Home Depot!
Apr 28, 2016 | Hampton Bay Dryers
My Makita "GA9020 9"" Angle Grinder has started to vibrate really bad.there seems to be play in the spindal.its used for floor sanding.i was thinking maybe bottom bearing,but just guessing any ideas thanks
Vibrations and excessive play could be caused by one of two or both bearings in the gear housing or the spiral bevel gears. Armature bearings can cause vibrations but usually don't show up as play at the spindle. Also, if the vibration is really bad, you could have several fan blades broke off one side of the armature fan throwing off the balance.
Oct 09, 2013 | Makita "GA9020 9"" Angle Grinder- 15 AMP-...
Need a wiring diagram for 3 speed patton floor fan
A three way switch has 3 terminals, these for floor fans operate by a rotary switch but can be adapted to use any 120V Rotary toggle or rocker type switch. technically your compartment (or room provided will determine which to use). I'd suggest you replace it with one like the one that no longer works. The one good thing about fans the direction they rotate in is already determined, and with a/c current it will work even if you connect it up wrong! If it work's then fine don't over think it
Oct 09, 2012 | Patton U2-1887HO Floor / Box Fan
Holmes HABF20 floor/box fan: broke one of the plastic feet that steadies the fan on the floor. Super glue no help. Are there replacement pieces available?
If you can't find a replacement plastic foot. You should be able to find rubber feet at a local Radio Shack. Replace the plastic feet with rubber feet. It will do the same. You may be able to find self-adhesive feet.
Jul 15, 2011 | Holmes Products HABF-20 Floor / Box Fan
I have a u2-1887. the speed control knob has broken off. i need a new speed control switch and knob
SAME THING HAPPENED TO MINE...THE SWITCH BROKE APART IN PIECES...WHERE CAN YOU GET ANOTHER SWITCH?
Oct 12, 2010 | Patton U2-1887HO Floor / Box Fan
Fan chain broke and i want to put it back together
If the chain broke from inside the fan you will need a new switch $6 at any home improvement store and if its just the chain links you can buy a another replacement one. Make sure you tell them which switch is broken, fan or light so you get the right one and how many speeds if its the fan
May 01, 2010 | Hampton Bay 24002 Ceiling Fan
Need replacement for lakewood box fan power cord
Use some needle nose pliers on the prongs and bend them back. They will be fine unless they broke off.
Aug 30, 2009 | Lakewood HV 18-c Floor / Box Fan
My dimplex wall fan heater fx20 switch broke and i
www.torreelectrics.co.uk/acatalog/Dimplex_wall_fan_heaters_FX20.html try this site
Jul 28, 2009 | Heating & Cooling
Hunter cieling fan switch replacement
My switch broke, so I'm in the process of replacing it.
Before taking it apart, I made note of the wire colors:
L=Black
1=Grey
2=Brown
3=Lt Blue
Jul 18, 2008 | Hunter 20761 52'' The Stratford II Brushed...
Dryers Logo
14 people viewed this question
Top Lakewood Dryers Experts
Jerry Greenberg
Jerry Greenberg
tfelton3
Jay Finke
Jay Finke
Are you a Lakewood Dryer Expert? Answer questions, earn points and help others
