Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Only one headphone works
Hi, my problem is that 1 headphone works no doubt. The problem is that if the connector of the earphone changes position the second earphone goes out, looses sound, or decreased performance. I tried the earphone on my brothers iPod and they worked perfectly fine. I would appreciate it if you can help me with this problem. Thanks and bye.
  • problemsansa May 26, 2008
    I have the same problem. This is my second Sansa c250, and they both had the same problem; only one earphone works.
  • lunilulu May 29, 2008
    I have exactly the same problem, does anybody have a solution...can you give an specific place where they can replace the plug or something?
    Thanks
  • 8,596 Answers
Hardware issue - must be replaced
Posted on May 25, 2008
My iPhone headphones won't work on my digilandl 718m tablet how can I get them to work on it?
Hi Amy
Be aware
There are different length's & thickness's of earphone plugs
Also the spacing on the earphone plug shaft between the black and silver connections may be out.
Take your tablet to a shop & checkout what works.
Cheers
Headphone connectors YouTube
Mar 14, 2016 | Tablets & eReaders
External speakers are working but headphones/earphones are not working on my computer
Maybe the headphone connector is broken. If that is correct you need to replace the motherboard. If you had connected the earphone and accidentally received a tug on the cable perhaps the earphone connector was damage.
Nov 18, 2010 | Computers & Internet
What can I do to fix a cable issue in my headphone? The right side doesn't work unless I move around the wire attached to the headphone.
Hi, what makes oneofthe earphones not to work,is because the wire inside the right side of the earphone hascut and will need to soldered back to it's position.
Open the right side of the earphone,and use a soldering iron and a lead to put back the wire properly.
after put back the wire,problem solved.
Thanks for using fixya..
Oct 27, 2010 | Skull Candy Ink'd Stereo Ear Bud...
Can you connect earphones to this TV? -GE25GT240 Serial #943516018
There is no front panel earphone jack for this TV. From the owners manual I can't find the rear view of this television. If there are connections on the back for AUDIO OUT there will be two connections for an RCA type connector. All you need to do is to get an adapter (from Radio Shack) and plug that into the two Audio Out connectors on the back of your television and plug your headphones into that adapter.
I recommend this one: http://www.amazon.com/Male-3-5mm-Stereo-Female-Y-Cable/dp/B000I23TTE
If you have a 1/4 headphone connector (the old type) you can convert the 1/8 to 1/4 inch with this one. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Delectronics&field-keywords=1%2F8+inch+male+to+1%2F4+inch+female&x=16&y=24
Apr 16, 2010 | GE 25GT240 25" TV
Headphone problem
Hi there and welcome at Fixya, the support team (lfete)
Please try with another pair of earphones and see if it works :O)
If it works with the another earphones, then you have to check yours :
1.See if the cable and connectors are ok
2.Try to move the cable a little bit all the way (you can move it up and down)
3.Then be sure that it is inserted the whole way in, some times you can connect the earphone nearly in to the product, that means one of the right/left side will not play.
If is still not working please return here again
Hope it helps
Have a nice time over there
Please rate my answer
Mar 12, 2010 | Audio Players & Recorders
I can only hear out of one headphone. I replaced the headphones and the problem still exists
Hi
does both of the earphones are new?
make sure you plugged the earphones properly .
If the earphones are new and connected properly then the problem is in the player connector and you probably have to take it to be fixed or even more simple buy new one.
Jul 16, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Problems getting sound to both channels
Try this see figure to get the idea...
How was it?
FIXYA me on this one... THANKS
Feb 06, 2008 | Olympus VN-3100PC Digital Voice Recorder
Headphones and sound.
Hey guys!
Since the internal speakers are working, the sound portion of your pc is set up correctly and working. That is also confirmed by the fact that the sound goes away when you insert the earphone jack.
That means that either your headphone jack is defective (I doubt that, since 2 of you seem to have the same problem, but possible), your earphones (or cables) are defective, or there is a compatibility problem with the earphone jack in the pc and the earphone plug on the earphone cable. Just because the plug fits the jack, doesn't mean that it's making the proper connection. I've been stung with that one myself, a time or two. That's about all there is to that circuit.
The only other thing that I might suggest is that you try to plug the earphones in, hold the Fn key while pressing the F8 key a couple of times. That key combination toggles you speakers on and off. Doubt that will buy you anything, but it's worth a try.
If you need any additional information, please feel free to ask. If this information has assisted you in the resolution of you problem, please return here to give my assistance an appropriate final rating. If this information has answered your question and/or lead to a resolution, please rate it as "Fixya!".
Thank you, and have a super day!
Ron-
Nov 29, 2007 | Acer Aspire 3680 Laptop
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
