Question about Winix WDH751 Dehumidifier
Turns on but fan and compresser does not run
Fan or compresser does not run
    Sergeant:
  • 448 Answers
Start relay on compressor fans will not work if pumps not running
Posted on Dec 06, 2013
T he compresser on my dehumidifier is loud, why is that.the fan that runs is guiet but when the compresser turns on it sounds like it is vibrating
It may not be setting on a level floor or the hardwood flooring or tile flooring is allowing it to vibrate more than it normally should. Also, remove the air intake filter to make sure it's clean.
Hope this helped you, Kathy. Please let me know. Thanks.
Jul 13, 2011 | LG LHD459EL Dehumidifier
You can hear compresser kick on and 5sec. latter a poping noise but the fan runs but no water.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jun 30, 2011 | Kenmore Dehumidifiers
The compressor on my Danby dehumidifier turns on for a few seconds, very weakly, and quickly cuts out. The fan and control panel are all working properly. The humidity is high enough for it to turn on...
Sounds like you've lost a lot of freon. Find the pump on your unit. Be careful, but after running it a while, touch the tube somewhere between the pump and cooling coils. If it is not hot then you have lost fluid. What happens is under normal working conditions the compressor would compress the freon making it hot, which then gets cooled by the radiator coils. In your case, there isn't enough fluid to compress to make it hot. Unfortunately, you need to have it refilled by a repair shop. Try your local A/C or HVAC shop. Don't be surprised if they can't refill with freon as it's bad for the ozone and being phased out.
May 04, 2011 | Danby DDR586R Dehumidifier
Whirlpool dehumidifier does remove water
indicates a gas leak and there is insufficient gas in the system
Oct 19, 2017 | Whirlpool AD50USS Dehumidifier
Compresser won't engage
check the thermocouple/sensor.
does fan run? also there could be a timer control.
Apr 04, 2010 | Maytag M7DH45B2A Dehumidifier
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
Year 2005 cycling fan and compressor
Your unit is probably operating in defrost mode. When you use a dehumidifier in a cold room, the condensing coils can freeze water. The unit senses this and thus stops the compressor until the water frozen on the coils melts. Then it resumes its cycle. This is a problem you will have during the winter months. It makes the operation of the unit inefficient, but this is otherwise normal behavior.
Jan 04, 2009 | LG LD50EL Dehumidifier
No water in the bucket
You most likely have a freon leak, or the compressor is not running. When the machine first turns on you should be able to see if the compressor is running or if it is just the fan. If the compressor is not running it does have a start devise and a relay on it that can be replaced. If the compressor is bad, most units have a 5 year warranty on the compressor, so contact the manufacturer for warranty service. If the compressor is running you have a freon leak, and it would need to be found, repaired and the freon replaced. This is a large repair, estimated charge for a leak repair would be around $149.99 The reason is the long time it takes to find the leak, and all the parts needed. Drier, valve, freon, etc.. Good luck, and I hope it is only the relay. You can get those relitively inexpencively. 3 in 1 kits are also good for a hard to start compressor. They give the compressor a little more kick to start it. They are about $28.00 and easy to install once you are to the compressor. I hope this will FixYa.
Mike
Sep 27, 2008 | Haier 45-Pint Dehumidifier
Winix WDH751 Dehumidifier Logo
137 people viewed this question
Top Winix Dehumidifiers Experts
Gil Shultz
Ken Wieczorek
Ken Wieczorek
Think Crucial
Think Crucial
Are you a Winix Dehumidifier Expert? Answer questions, earn points and help others
