Question about Primos Truth Cam 46
Will not power on
Will not come on after changing battries out
The battry died after charging it didint turn on till now
change the battry or if it is in warrenty then give it in that
Nov 28, 2013 | Sony Ericsson SonyEricsson Xperia X1 AA...
I have a 96 s10 blazer with a 4.3 starts hard idles rough wants to stall has misfire and when I turn on the blinker the battery gauge moves with it and when in park if I Rev the motor the speedometer and...
Have you checked the voltage at the batry when running? Sounds like alternator is not working properly. The battry is only used for starting, once started the alternator runs all the accesories & charges the battry. If not chargeing the vehicle will **** battry power. You may have a good battry surface voltage but a bad battry. The battry should be load tested as well.
Jun 24, 2012 | Cars & Trucks
I have a Compaq Presario R3000 with Windows XP OS. Until recently it had been working fine. Suddenly, the power went off while still connected to the AC Supply and the Laptop just went off. The battery...
1. Remove battery from the laptop. 2. Unplug the power cord from the computer. 3. Let the computer sit for a few min. 4. Leave battery out. 5. Connect power adapter to computer 6. Push power button to turn computer on. 7. If computer powers on shut down again, and put battery back in. 8. Push power button to turn computer back on (at this point battery and power adapter should be connected to the computer)
If computer powers on with power adapter with the battery out. You are having a battery issue. You would want to look into replacing the battery. If computer does not power on with just the power adapter. You are most likely having a power issue. Depending on how old the laptop is. You will either want to contact the manufacturer. Or take the computer to a computer repair shop, or consider replacing the laptop.
May 31, 2011 | Compaq Presario R3000 Notebook
3110c charging show but battry no charg solution
you should change the battry of your cell it can help you try new battry daer
Nov 02, 2010 | Nokia 3110 Cellular Phone
How do i know when to replace batteries ?
There's no sure way to know when to change the batteries. I'd suggest you change them at least once a year. Plan on it when you do your smoke alarm battery change, which should be done at least annually.
Jan 26, 2010 | Weiser Lock Powerbolt 1000 Lock
3500 watt pure sin wave inverter
This engineer, Mandfred has a "Nightmare Story" for you ...
http://ludens.cl/Electron/chinverter/chinverter.html
If you have the exact same model, Power Jack 3500, then I seriously doubt you will ever get your inverter working long term without making all/most of the modifications that he made.
Oct 26, 2008 | Statpower PW-1750 Triple Outlet 1750 Watt...
Camera wont turn on even with new batteries
In order to narrow down the issue, I suggest you the following steps. 1) First of all we have to power drain the Camera. Take out the battries and unplug adaptor, now hold the power on putton ( Click Button) for a minute this will clear the static power on Camera. If this doesn't fix the issue, Than.... 2) As cam is working fine with Ac adaport and batterys are not working you have to check the cam with the new battries. If you store battries for a long time with out using them, they may result in battery drain. If this doesn't work. 3) Then it need a Physical check, where we can track if Power suply from battries are reaching till its destination or not. This is the way to narrow down the issue. Thanks you.
Apr 08, 2007 | Konica Minolta DiMAGE Z1 Digital Camera
Primos Truth Cam 46 Logo
26 people viewed this question
Top Primos Home Security Experts
Gabriel Olusegun...
Da Doc
Are you a Primos Home Security Expert? Answer questions, earn points and help others
