Question about Mr. Heater Portable Propane Forced Air Heater - 35,000 BTU
Thermo coupler where can I get a thermo coupler for a remingtion 35000 propane heater
  • 24 Answers
Spaceheaterparts.com
Posted on Mar 10, 2014
Propane heater wont stay running
is the sensor for the thermocouple located in the right spot in the flame,remove it and if you have access to a propane torch,heat the end till its red hot and leave it connected to the gas valve,then start the unit and this will tell you if the sensor is properly positioned in the pilot flame on the unit itself,if not you could have a defective new thermocouple or another safety device keeping it from staying lit or the gas valve is faulty
Jul 28, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Pool heater shuts off after a few second
You didn't indicate your exact model. There are different versions of the H200 series. If it is milivolt then there is no electric, Must have correct milli-volt pilot generator. If it's electronic, check the air flow pressure switch on the combustion air.
Jul 17, 2010 | Hayward H Series Pool & Spa Heater 400k...
Cant get my heater to stay ignited
THERMO COUPLER, COPPER PEICE INSIDE TUBE MAKE SURE THE FLAME IS IN CONTACT WITH THIS PEICE, 99 PERCENT OF THE TIME IF A UNIT HEATER, WATER HEATER ETC WILL NOT STAY ON AND DOES WHEN YOU HOLD IT IN IT IS THE THERMO COUPLER
Jan 20, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
I have universal 350,000 propane heater. Fan runs, but switch will not turn on to allow propane to burner.
The thermo coupler is at fault. If pilot won't stay lit thermo coupler keeps gas off. So, Unless it is a bbQ , make sure the pilot is on or the thermocoupler stays hot while the gas is on.
May 25, 2009 | Heating & Cooling
I have a 35000 btu propane reddy heater that wont ignite .
the thermocouple is bad.it needs to send a signal to the gas valve to say it's okay to stay running.replace it and the problem should go away.if not let me know
Mar 13, 2009 | Reddy Heater-30-55,000 BTU Variable
How do i install a thermal coupler for forced air heater gas
Thermo coupler is held in place with a clamp bracket at the pilot end and a small brass line nut on the other end going into the gas valve.The pilot flame must surround the sensing bu or wrap itself around it Press the pilot button for a few seconds and fire up the pilot flame. Wait a few more minutes and turn the gas vale on for the main burners. If it fires, your set.Good Luck,Ned
Jan 15, 2009 | Reddy Heater RLP100 Portable Forced Air...
Mr. Heater Portable Propane Forced Air Heater - 35,000 BTU Logo
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
