Question about Megger VF2 Ac Voltage Detector
How to insert batteries
Just purchase megger VF2 noinstruction Can you advise how to insert 2 batteries please
Will a steering knuckle & Hub of any other year of car fit on my 1993 Saturn SL?
probably not as the unit is made specifically for your make and year of car
if the production run of the car lasted several years then it may fit unless there has been changes to the suspension
check it out at an accredited suspension specialist as they will have list to cross over the parts
Nov 23, 2015 | Megger DET24C-VIP - DET24C-VIP...
Br.d code for megger
Nothing you can do, send back to Megger to get repaired.
Oct 24, 2013 | Megger MIT1020/2 Megohmmeter, Battery
What does the three volt battery do
All meters capable of resistance measurements require batteries to power the circuit under test and meter movement.
Some manufacturers prefer to use 2 different voltage sources to be applied to specific ranges offered. They use the lower voltage for low resistance ranges and higher voltages for high resistance ranges. Doing this help prevent larger currents (and wattages) from flowing in the component or circuit under test when the low resistance ranges are selected.
Higher resistance components and circuits will have significantly lower current flow (and lower wattages), so a higher voltage is supported and provides greater resolution of measured values on the meter.
I hope this helps & good luck!
Oct 05, 2012 | Measuring Tools & Sensors
BR.D Code
get it serviced at Megger
Sep 18, 2012 | Megger MIT1020/2 Megohmmeter, Battery
Megger MTI 1020/2 I got E79 in screen what dose it mean thank you
I checked the user manual and could not find an answer to your question. Try calling this service center:
Megger
4271 Bronze Way, Dallas,
Texas 75237-1019 USA
T +1 800 723 2861 (USA ONLY)
T +1 214 333 3201
F +1 214 331 7399
E ussales@megger.com
Mar 15, 2011 | RTO Megger 10 Kv Insulation Resistance...
Megger VF2 Ac Voltage Detector Logo
Top Megger Measuring Tools & Sensors Experts
Vuk B
Bill Boyd
ka4iup
ka4iup
Are you a Megger Measuring Tool and Sensor Expert? Answer questions, earn points and help others
