Question about Dryers
Blowing heating element
I bought a new whirlpool dryer 1 1/2 years ago i had to replace the heating element three times now i need a fourth one i replaced all the venting pipes now the element blew up and melted the wires and blows out my fuse i had an electrician come to my house and all eletrical curents are good whirlpool tells me its normal for this to happen and just replace the element again at 75 bucks an element and going on #4 in a year and a half to me this is not normal can you tell me what to do and how to correct this thanks
  • 4 Answers
Wow. Doesn't sound normal to me. I have two thoughts going through my head. One is that perhaps the blower fan is bad and not giving it the proper air flow. However the high limit switch should shut off if it gets too hot, which leaves me to believe the thermostat and/ or the high limit switch are bad. Naturally you want to vent the shortest distance possible. Good Luck. I know a good repairman could locate the problem. That's the problem, finding a trustworthy repairman. If you do hold onto him. Good Luck
Posted on Oct 13, 2007
My whirlpool dryer 3394996 is about 10 years old or more and it wont heat up everything else seems to b normal
This is either a heating element (most likely and easy to replace) or it is one of your heat sensors. Should be three of them. Still very easy to replace and I would do all three at the same time rather than just the bad one. You can tell if it is the element by looking for a break in the wire on the element or pull it off and hook it direct to current to see if it heats(glows).
Nov 10, 2015 | Whirlpool Dryers
Clothes dryer shorts every time I turn it on
I assume this is electric dryer vs gas. You most likely have a electric heating element that has broken, and the wire is shorted to cabinet. If you can see inside element, you can often spot the broken wire. Don't try to fix element, you can't splice heating wire, it wont work. Buy a new element.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/perry_14036f9bc71cde6a
Jan 08, 2015 | Dryers
Whirlpool dryer bad heating element AGAIN
Hi Warren Fink
Try this solution to your problem
A vent clogged with lint can cause the dryer to overheat.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
Please take time to rate me
Bud
Oct 18, 2012 | Whirlpool Dryers
Dryer not working
check to see if your vents are clogged its the num. 1 reason. if they are most likely your thermal fuse blew out, have it replaced. Another reason is your heating element went bad. Check for continuity on both items.
Apr 16, 2010 | Whirlpool LER4634J Electric Dryer
No heat
Try testing the voltage across both fuses. The time you swapped fuses, and the motor ran without heat indicates to me that one of your hot leads is not getting voltage. On a three wire system, you should have two 110v leads and a common. Make sure that the cord is connected properly, and the same for the receptacle that you plug into. Test the receptacle as well for proper voltage and a good common ground.
Hope that this helps. Please repost if necessary.....Operators are standing by......!
Regards, --W/D--
Jul 18, 2009 | Whirlpool Dryers
Dryer runs but does not get hot
IT IS YOUR HEATING ELEMENT THAT IS GONE. YOU CAN BUY A NEW HEATING ELEMENT AT LOWE'S HARDWARE OR WHEREEVER YOU BOUGHT YOUR DRYER FROM. JEFF THIS IS A COMON PROBLEM IN ALOT OF DRYERS. I HELPED MY FATHER (WHO DIED IN 2006) REPLACE A HEATING ELEMENT ON OUR DRYER YEARS AGO WHEN I GOT HOME FROM WORK. IT IS THE HEATING ELEMENT. GOOD LUCK.
BEST REGARDS,
RODNEY
May 14, 2009 | Maytag Washing Machines
WHIRLPOOL DRYER MODEL LEQ8858JQO
Thermostat, High limit and low limit thermostat or even a safety Temp limiter. All three are similar in cost and located on the back inside of the dryer and 1 by the airflow tube under the lint trap.
Apr 08, 2008 | Whirlpool LEQ8858J Dryer
Dryers Logo
106 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
