Question about Samsung Computers & Internet
How I will clean my Laptop Keyboard.
How will I clean my Laptop keyboard.As some particles like hair,dust chips of particle got inside of my keyboard.
    Sergeant:
  • Samsung Expert
  • 352 Answers
Hi Shravan Chakravarty,
You may want to refer the below link to clean the laptop keyboard:
http://bit.ly/qCVqTs
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Posted on Nov 16, 2013
4 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: HP Compaq NX960 Laptop Keyboard Problem
This is generally a sensitivity issue with the keyboard. It's usually caused when the rubber depressors that activate each key start getting worn. Sometimes you can take each key off individually, take off the rubber depressor and clean the contact point on the keyboard and up inside the depressor where it makes contact. Clean it with with rubbing alcohol and Q-tips. This is alot of work and only fixes the problem about 60% of the time. Your only other option is replacing the keyboard.
Posted on Jul 23, 2008
  • 15 Answers
SOURCE: replacing keyboard for advent 7108 laptop
I have had the same problem several times over and it is VERY likely that the liquid has reached other components (specifically the motherboard) and will corrode anything that the liquid has come to rest on. The keyboard itself is easy enough to remove and replace, but the only place I am finding parts for advents is in the UK. This means replacement of the keyboard COULD be costly and in the long run the computer may fail due to corrosion especially if it was pop or juice or any other acidic liquid. Here is the link I found for a possible solution.  http:/www.adventspares.co.uk  if they dont have it, these guys might... http://www.techno-mart.co.uk/advent.html
Good luck, and I hope you havent damaged your motherboard! Kirk
Posted on Feb 27, 2009
SOURCE: hp dv7 keyboard issue
Hey guys, I just had this problem, I have alot of problems with my DV7 laptop, top panel started malfunctioning, then it thought i was turning the volume up and down by myself, also my g h ' and backspace stopped working along with other problems that I don't want to bore you guys with, whats the answer? Remove the battery for 10-15 seconds and clean the connectors and this has ALWAYS fixed all my problems. Hope this helps.
Posted on Jan 26, 2010
Bn and spacebar not working on my lenovo laptop
Remove the keyboard slowly, clean it up and put it back....either dust particles are jamming the spacebar.
Jun 16, 2014 | Sony for Sony VAIO VGN-SZ51B/B VGN-SZ52B/B...
Tip
Cleaning your Keyoard
Hello
This is a tip explaining exactly what steps you you should follow if you would like to Clean your keyboard. What usually happens, is that keys get stuck, due to dust particles or faulty rubbesr under the keys itself.
Before we start cleaning, you need to shut down your computer and unplug your keyboard from either the USB slot, or the PS2 port.
Now, you will need:
  • Some Spirits/alcohol
  • Cotton swabs
  • high static cloth/cleaning cloth
  • Vacuum or compressed air
  • Clean, soft paint brush
  • And lastly, some patients..
Step1
Ok, the first step will be to place your keyboard in front of you on a level surface.
Now, either use a vacuum or some compressed air to ****/blow out the particles beneath the keys. If you use a vacuum or compressed air, turn the keyboard downwards so that gravity will pull the particles down as well.
Step 2:
When you are done removing the particles underneath the keys, place the keyboard on a flat surface like figure 1. Now you will need to dip the cotton swabs into the alcohol or spirits and clean the tiny spaces between each key.
Step 3:
Now, after you have claened all the tiny spaces between the keys as seen in figure 2, i usually use a regular soft paint brush and just brush off the whole keyboard, at the side of the keys, as well as the bottom side.
Step 4:
Lastly, take the cleaning cloth and put some alcohol on it. Now wipe clean the whole keyboard after you have completed the abovementioned steps.
Now, you are done. Just plug the keyboard back in, and start up your computer. I always keep my soft paint brush near, to minimize the dust builup on the keyboard between cleaning periods.
Hope you can find this helpfull and rate acordingly.
Kind regards
Andrea
on Feb 23, 2010 | Computers & Internet
Num lock not working in asus r500a
maybe you need to clean the keyboard see if nothing is inside it i would turn it upside down and shake out the food particles and dust inside the keyboard if the key itself is broken only way is to replace it.
Apr 06, 2014 | Asus Notebooks R500A-RS51 Laptop
Message keeps popping up saying Turn off computer, problem in cooling system
you need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 25, 2013 | Toshiba Satellite 1715XCDS Cooling Fan...
Warning cooling system is not working on my laptop
You need to get pressurized air and blow the vents to remove dust particles causing over heat. Or if possible remove keyboard to expose cooling fan and chip and use pressurized air to blow off dust
Nov 21, 2013 | Toshiba Computers & Internet
Laptop making noise
Aug 06, 2013 | Toshiba Computers & Internet
Why My fan is runing to often? I have Toshiba Laptop satellite L645
Oct 08, 2012 | Toshiba (K000016310) Cooling Fan
In my laptop some keys are not working
Probably that is a result of sticky dust particles under the keys of your keyboard. Get your computer to a computer technician to open it up and blow and clean the dust off. The cleaning should be done using benzene
Dec 15, 2011 | Toshiba Satellite M45-S331 Notebook
Letter a doesnt work
check that if your keyboard contains any dust particles if so clean it with brush by removing the keys one by one check the connections of the keyboard cable to the system and also try to connect with other system too check the cable for any kind of damage
Oct 18, 2009 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Laptop keyboard not operational
If you replaced the keyboard with a Dell replacement 1501 keyboard and it still doesn’t work then yes the motherboard will probably have to be replaced. If your son spilled water on the laptop it could clear up after it completely dries. If it was juice, soft drink or sport drink the laptop could develop other issues. The syrup in these kinds of drinks don’t evaporate, they just remain there and accumulate foreign particles like dust, hair, dirt and eventually start to corrode electrical contacts like acid. Similar to the terminal posts on a car battery.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Apr 28, 2009 | Dell Inspiron 1501 Notebook
Computers & Internet Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
