MY AIR CONDITIONER REMOTE CONTROL IS NOT ON FARENHIGHT .MODEL UL-R51M/CE
HOW YOU SET THE AIR CONDITIONER FROM CELCIUS TO FARENHIGHT
    Master:
  • 613 Answers
Search one of these videos
Posted on Dec 08, 2013
4 Suggested Answers
SOURCE: I have a goodman mini
To change from Cecilius to Fahrenheit on the remote control, hold both the + and the - simultaneously and this will enable you to toggle between C and F. You will need to do this each time you change your batteries.
Posted on May 12, 2012
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
  • 86 Answers
SOURCE: Westpoint split air conditoner remote contol unit
1.model no.
2.capacity of yr unit.
3 brand name.
mailme mintex007@yahoo.com
i can send to u
Posted on Mar 16, 2008
I want to find a frigidaire control remote UL-R51M/CE
Hey Ralph, thanks for your post!
I see that you need help locating the remote for your Frigidaire refrigerator. In order to better assist you I would need to have your model number. You can locate the model number on the inside wall of the refrigerator. Once I have that information I would be happy to assist you further. -Matt
Apr 27, 2016 | Frigidaire Refrigerators
Why does the split unit blow hot air in air conditioner mode, when switched on with the remote control.
because you have the temperature set at 28 degrees celcuis . Change the temperature to 18 degrees and it will cool 28 is hotter
It is a reverse cycle air conditioner it will warm the room if you set temperature to 28 degrees . Set it lower and it will blow out cold air.
Have exact same air conditioner as I recognise the remote control.
point it at the air conditioner when altering the temperature setting.
Check under the slide compartment also on the remote for more advanced settings.
Jul 02, 2015 | Cfm Daikin R410a Split System Air...
I have a goodman mini split.The remote is set to celcius,how do I get it to fahrenheit.model WMH24-1A
Aug 14, 2011 | Sanyo 09KHS51 Ductless Mini Split Air...
I have a hauzen wall (ducted) fan/air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an...
i have a hauzen air conditioner. how do i use the remote to get cooler air? It is currently on 30 degrees celcius. the remote is in korean and i speak/read english. the remote has an orange button to turn on and off... can you send me an english manual link? the wall unit is about 3 feet and also has a grey button on the right front bottom unit to turn it on and off. above that on the front right flat side are 5 small round lights that let you know how you have the unit set. hope this description helps you understand what kind of unit i have... i cannot read korean to be more clear. i would appreciate it if you can send a user guide in english. thank you
Jul 24, 2011 | Heating & Cooling
What is the price of this unit??
It's hard to give you a price range, as that model has apparently been discontinued by the manufacturer.
Jul 13, 2011 | Continental CE-PAC1163 Castle Series 11000...
Can not figure out how to control thermostat
If you take off the front control panel cover (simply prying off on the edge with finger) you will find 2 small buttons under the display panel, one being mode and the other being prog.
Press both simultaneously and hold down for 5 secs and the display will blink, press prog to advance to what you want to program, kinda like setting a timex watch. As I recall you can set degrees celcius or farenhight/ cycle/Hi/Lo etc.
Just keep in mind when you set using the up and down arrows:
flashing H means: at what temp do you want HEAT to kick in?
flashing C means: at what temp do you want AC (if you have it) to kick in....if no A/C fan simply blows air.
Hope that helps.
May 03, 2009 | Heating & Cooling
Need to know what the icons stand for on remote control for Toshiba Split System Air Conditioner. Don't have a manual?
Generally all the symbols on each unit are the same. The snowflake does cooling, the sun does heating, the fan does fan only mode, the water droplet does dehumidify and the arrows means automatic mode. The increasing bars refers to the fan speed.
Mat
Apr 25, 2009 | Continental Electric CE-AC7581 Ductless...
Broken remote control of a continental electric minisplit
RemoteControlDirectory.Info/ just click for information the best remote cxontrol for aircon.
Jan 06, 2008 | Continental CE-AC75271 Ductless Mini Split...
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Heating & Cooling Logo
87 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
