Question about Vizio VSB210WS Soundbar
Only white lights showing on sound bar after turned on
After I power up sound bar, only the white LED lights on sound bar come on and it does not function.
Riso RZ 220UI shows horizontal bars
you have to change the whole unit of your led light. the bar with all those led lights are attached or soldered. hope to be of help.
Jan 03, 2014 | Riso Office Equipment & Supplies
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
How to fix fluval led
on this tank the lights are built into the filter pump housing , if they go bad it might be possible to retrofit a new sealed light bar into the same space , but you will need to have previous knowledge of electronics and specify L.E.D. lights as they don't work like regular light bulbs but require a special kind of power or will be damaged if hooked to wrong type of power I suppose its possible to use batterys but id have no idea how long that would work
Jan 29, 2013 | Fluval LED Edge Aquarium 6-Gallon Aquarium...
Schematic for vizio vbs210ws
According to the user manual, the fourthj LED flashing (Error D) means that a thermal (heat) shutdown happened. If Error D, Thermal shutdown, is indicated, turn off the Sound Bar and verify the ventilation slots in the Sound Bar are clear, the Sound Bar has proper ventilation and is not being operated in an environment
that is too hot. If these conditions exist, reduce the volume level for the particular source content being played. My bar did this and I left it disconnected from the Ac power a full day , and it powered up the next day.
Aug 30, 2012 | Vizio VSB210WS Soundbar
47"Vizio model #XVTSV Led LCD
this is the only way to get rid of the orange light: l3_3_in_hdtv_lcd_television_412611.jpg
  • Connect
  • reset
  • Blurr
  • installation
  • trouble
  • settings
  • service menu
  • set
  • channel
  • parts
  • instructions
  • troubleshooting
  • remote
  • connection
  • drivers
  • blue
  • repair
  • manual
  • bug
  • CODES
Problem with Vizio L32 32 in. HDTV LCD Television
how do i turn off the orange light on the vizio tv, it won't go off after the tv is turned off?
Posted by avatar1.jpgmeg_car on Jul 08, 2009
Vizio TV Repair Power supply troubleshooting Picture problem Sound problem
  • Service by: avatar6.jpgmjsazon
  • 5 Stars
  • Email
Solutions (2) Best Solution That little fella is only turned off by unplugging it. If all those little lights in America could be turned off we could do with one less nuclear power plant. If unplugging it is not an option, my wife's solution is to cover it with a piece of black tape.
+ Add a comment
remove all screws on the back of the tv, carefully pull off back cover. you will see two circuit boards one on the left (Power) and one on the right (Video) on the Video board there is a small plug on the right side with a yellow, white and red wire going into a small white connector. the red wire is what controls the orange light on the front. now that the plug is pulled turn it over and you should see a small white plastic piece that holds each metal connector on the end of the wires in. pry this piece of plastic up for the red wire and pull at the same time, the wire will come out of the connector. now tape the metal connector with electrical tape and tuck it behind something or tape it to the chassis. plug your connector back in. put the rear cover back on. now your tv will only show the vizio logo in white when you have the power on. If you wish to disable the logo for both orange and white just disconnect the white plug completely.
May 16, 2011 | Vizio XVT473SV 47 in. LCD HDTV
Have a weird problem M50WH74S RCA
i found out tht it could be the (DMD) Digital_Micromirror_Device i dont know if that is you problem or not
Sep 17, 2008 | RCA HD52W56 52" Rear Projection HDTV
Vizio VSB210WS Soundbar Logo
37 people viewed this question
Top Vizio Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Vizio Audio Player and Recorder Expert? Answer questions, earn points and help others
