Question about Ovens
I need to find out the specs (size) for my kenmore 911-3042990. I am replacing it and need to know what size oven to look for.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Try measuring it
Posted on Nov 22, 2013
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28³??" (73.0 cm) H x 26³??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
How can we calibrate the oven temperature?
Older oven or newer oven? Old school ovens have a screw in the hollow stem yall can tweak. The new ovens have a themobilian_2771.jpgsensor.
If your oven has a sensor it should read around 1100 ohms at room tempt. If it is out of spec, shorted to frame or open then the fancy shocktronic oven control won't know what the oven temp is.
If you want a great answer post a make and model.
Aug 06, 2011 | Kenmore Ovens
My son needs to know the wattage of our stove , it is a kenmore self cleaning oven. I don't know the model because we are renters
The model number on many ranges is located on a plate that is on the frame in front of the right or left front leveling leg of the range. To view this plate, pull the bottom drawer out. On some ranges, the model number plate is located on one side of the oven door opening. You may find it in this location on your range. You may even find the wattage on this label. Once you find the model # click below to find the manual for the specs if you do not find the wattage on the label.
Manual Search
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Kenmore Ovens
Broken Bottom Element
Remove the element and take it with you to a appliance parts supply.
They will match it with the correct replacement.
Mar 25, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven
The igniter may need to be replaced again. The only way to know is to test it to see if it has enough amperage to light the gas. If it glows, but no lighting of the gas, get it tested.
Mar 21, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Kenmore oven clock control installation instructions
Your prpblem is not the control, it is a short circuit in the ribbon cable between the keypad and control. You can find my fix at:
http://fp1.centurytel.net/Powerman/Dreaded%20F7%20Problem.pdf
I have now shared this with over 1400 folks and most report success.
Please let me know if this works for you. Email me at:
hutchipop@yahoo.com
Nov 21, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
51 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
