Question about Ovens
I need to get the specs (size) for my kenmore 911-3042990. I am going to replace it but I need to know what size oven I'm looking for...
Need Specs and sizes for a 1989 KitchenAid Superba 27 - KBS277
Are you sure of the model number? I see several KitchenAid ovens with the model number KEBS277: http://www.kitchenaid.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10552&langId=-1&storeId=10202 . The single oven version is 28³??" (73.0 cm) H x 26³??" (67.9 cm) W x 23" (58.4 cm) D.
I hope this helps.
Sep 03, 2016 | KitchenAid Ovens
Need same size replacement W x H
Rick,
Getting an exact match might be hard. I would suggest starting with the same brand you have and go to their website and look at the specs page and that will show you what you would need to be looking for. The other option that I can think of is contacting a local appliance store in your area and give them the dimensions of what you are looking for and let them do the leg work and see what they can come up with for you.
Apr 22, 2015 | Ovens
Jrp24bod1bb GE Double Oven
you would need a minimum of 48&1/8" high,23&1/2" Deep, and 22&1/2" wide and 14" off the floor for ventilation per G.E quick specs
Feb 18, 2013 | GE JRP24 Electric Double Oven
My Kenmore propane oven is taking long then time needed to bake something
A very common problem when gas(both propane and natural) oven takes longer to heat properly is going to be a weak igniter . Since its weak its not fully opening the gas valve and not enough gas is flowing to produce the proper flame size/heat. By replacing the oven igniter it will heat as its supposed to .
GENE
Sep 24, 2011 | Kenmore Ovens
My son needs to know the wattage of our stove , it is a kenmore self cleaning oven. I don't know the model because we are renters
The model number on many ranges is located on a plate that is on the frame in front of the right or left front leveling leg of the range. To view this plate, pull the bottom drawer out. On some ranges, the model number plate is located on one side of the oven door opening. You may find it in this location on your range. You may even find the wattage on this label. Once you find the model # click below to find the manual for the specs if you do not find the wattage on the label.
Manual Search
Hope this helps.
Zeppelinx12
Feb 25, 2011 | Kenmore Ovens
F3-error. Kenmore classic oven Heating element will not go pass 100 deg. Heating element recently replaced. Broiler is also malfunctioning
Hello there:
Whenever you get the dreaded f-3 code this is the code that tells you that the temperature sensor is going bad or already has gone bad and needs to be replaced immediatly. It should look something like this and cost about 50 dollars
Jun 20, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Bottom of kenmore oven pitted
Baked on debris causes this. The spots are from food sitting there without being cleaned.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 08, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
Kenmore smoothtop model 911.9554590 duel size burners
the inner burner is broken so the whole thing needs to be replaced. check your owners manuel for warrenty times on the burner. otherwise just replace the burner and that will solve your problem..
Mar 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
