Question about Refrigerators
MY UL-R51M/CE REMOTE IS FOR FARENHIGHT TEMP.BUT NOW IS ON CELSIUS.HOW CAN I SET IT TO FARENHIGHT
THIS IS A FARENHIGHT REMOTE.BUT IS ON CELCIUS NOW.I LIKE TO KNOW HOW TO SET IT TO FARENHIGHT TEMP.
I want to find a frigidaire control remote UL-R51M/CE
Hey Ralph, thanks for your post!
I see that you need help locating the remote for your Frigidaire refrigerator. In order to better assist you I would need to have your model number. You can locate the model number on the inside wall of the refrigerator. Once I have that information I would be happy to assist you further. -Matt
Apr 27, 2016 | Frigidaire Refrigerators
How to change from Fahrenheit to celcius
formulas and examples here
http://albireo.ch/temperatureconverter/formula.htm
Mar 13, 2015 | Cars & Trucks
Convert farenhight to celcius
Subtract 32 then multiply by 1.8
May 04, 2014 | Office Equipment & Supplies
How to change from celcius to fahrenheit? How did get change by it's self?
Try the following. Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Nov 23, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Are the units indicated for the oven in Celsius?
Unless it is a very old oven then the temp markings are in Celcius, as is common to most ovens today.
Please rate my comments.
Thankyou.
Jul 15, 2009 | Candy Ovens
Can not figure out how to control thermostat
If you take off the front control panel cover (simply prying off on the edge with finger) you will find 2 small buttons under the display panel, one being mode and the other being prog.
Press both simultaneously and hold down for 5 secs and the display will blink, press prog to advance to what you want to program, kinda like setting a timex watch. As I recall you can set degrees celcius or farenhight/ cycle/Hi/Lo etc.
Just keep in mind when you set using the up and down arrows:
flashing H means: at what temp do you want HEAT to kick in?
flashing C means: at what temp do you want AC (if you have it) to kick in....if no A/C fan simply blows air.
Hope that helps.
May 03, 2009 | Heating & Cooling
Refrigerators Logo
37 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
